Originally Posted by Got the Bug
So the Dyno results that Roush provided me with my engine are not actual results? Same thing with a KC engine or a Ford Crate Motor?
Never been on a Dyno to see what the readings are at the rear wheels. Don't really care.
To a certain extent, yes. Especially if they dyno'd you with open pipes, even more so if the water pump was not running, extra even more so if they dialed in a "compensation factor," etc. The only true numbers that you can believe are the ones you see with your own eyes on a chassis dyno.
