Old 10-12-2009, 11:43 PM
bobcowan's Avatar
bobcowan bobcowan is offline
Originally Posted by afret View Post
This Mallory has the Duraspark pickup like what Ford used to put in their cars. Should be pretty durable and easy to find replacements if it ever goes bad. I've used to run a Unilite long ago. Had no problems with it but it tends to be pretty voltage sensitive and is expensive to replace.
But is there any reason the magnetic is better than optical? Mallory makes both. Why would you choose one over the other? Is the magnetic less voltage sensative? Will the pick up last longer?
