AC Cobra
http://www.clubcobra.com/forums/ac-cobra/)
| kayakjack |
11-29-2006 10:25 AM |
Transmission (Tremec) shop in Atlanta
Any suggestion regarding an Atlanta area shop to fix the leak in my Tremec 3550?
I'm new to this so I wonder what the local guys do.
Thank you,
Jack
| blykins |
11-29-2006 10:36 AM |
If it's an output shaft seal, just change it yourself. Not a hard job at all. Hardest part is pulling the driveshaft out.
| Tony Radford |
12-05-2006 04:16 PM |
Check out Vintage Mustang in Decatur. They can change a bushing without removing the tail shaft housing.
| kayakjack |
12-05-2006 04:48 PM |
Thanks Tony,
Jack
| rcassidy |
02-08-2007 02:23 PM |
Just an FYI, I found that Southern Gear in Symrna is the only authorized Tremec repair shop in ATL. Little late to the party, but an FYI for everyone.
| chipperb |
02-10-2007 05:59 PM |
Try Max at 404-838-8606 in Decatur. Vet that does classic cars and bikes. Has an 1967 Mustanfg that he uses as a daily driver and added a/c, 4 speed, disc front brakes and all the paint/body work. He was a submariner in the Navy and can do about anything, including fabricate. He has a complete machine shop too. He has done one project for me already and has a second project now. Out of the Navy and trying to start building a business. cb
| kayakjack |
02-10-2007 06:17 PM |
My trans leak was coming from the speedometer cable. I removed it from the trans. - cleaned it up real good with brake cleaner. Then put silicone RTV around where the cable is crimped just before it enters the trans. Reinstalled it.
The leak is history. Easy fix. I didn't want it to be some gasket that requires pulling the trans and taking it apart. It wasn't.
Jack
| chipperb |
02-10-2007 06:42 PM |
GOOD FOR YOU! I have learned to work on these beasts (except body work) because no one else will! cb
| kayakjack |
02-10-2007 07:12 PM |
Thanks Chip!! I have a long way to go before I can qualify to be a "shade tree" mechanic. But it is part of the fun.
Jack
| All times are GMT -7. The time now is 12:03 PM. |
