-   Advertisers Forum (http://www.clubcobra.com/forums/advertisers-forum/)
-   -   B2 Motorsports 445FE Complete Engine (http://www.clubcobra.com/forums/advertisers-forum/112022-b2-motorsports-445fe-complete-engine.html)
blykins 08-08-2011 05:22 AM
Complete engine, dyno tested and ready to drop in the car. Compare to other builders' engines that lack the details....oil filter adapters, alternators, water necks, coils, coil brackets, etc.
*Machined Ford 390FE Block
*ARP Main Bolts
*Scat 4.250" Crankshaft
*Scat 6.700" I-Beam Rods
*Probe Forged Pistons
*Mahle Rings
*Clevite Bearings
*Professional Products Balancer
*Felpro Main Seal
*Ford Racing Timing Chain
*New Crank Spacer
*Custom Comp Cams Hydraulic Roller Cam
*Morel Lifters
*Melling HV Pump
*ARP Oil Drive
*Moroso Front Sump Pan, Pickup
*Edelbrock Heads
*T&D Rocker Arms
*Trend Pushrods
*ARP Head Bolts
*Edelbrock Performer RPM Intake
*Edelbrock Water Pump
*MSD Distributor/Plug Wires
*Ford Racing Valve Covers
*Quickfuel Carb
*Pulleys/Alternator Bracket
*PCV Valve/Breather
*MSD Coil/Bracket
*1 Wire Alternator
*Oil Filter Adapter
*Water Neck
$11999
blykins 08-08-2011 05:24 AM
Can also be built in a more "budget" minded fashion, with a factory replacement water pump, Duraspark distributor, PRW rocker arms, Eagle crankshaft and rods, etc.
