-   Advertisers Forum (http://www.clubcobra.com/forums/advertisers-forum/)
-   -   B2 Motorsports 427 ZL1 BBC Complete Engine Package (http://www.clubcobra.com/forums/advertisers-forum/112362-b2-motorsports-427-zl1-bbc-complete-engine-package.html)
blykins 09-01-2011 06:21 AM
I know that there are members here that don't bleed as blue as I do, so it's only fair that we offer some GM engine packages as well.
I was pretty shocked at the sticker price for the all aluminum ZL1 engine provided by GMPP. I decided to offer something better.....and cheaper.
Here's what you get:
*GM Performance Aluminum ZL1 Engine Block, Fully Machined
*Clevite Main/Rod Bearings
*Eagle Forged 3.760” Crankshaft
*Scat Forged Rods
*Diamond Custom Forged Pistons
*Mahle Rings
*Cloyes Timing Chain Set
*Comp Cams Hydraulic Roller Camshaft
*Comp Cams Hydraulic Roller Lifters
*Moroso Oil Pan/Pickup
*ATI Harmonic Balancer
*Melling HV Oil Pump
*ARP Camshaft/Balancer Bolts
*AFR Aluminum Heads
*Comp Cams Valvetrain Components
*Felpro Gaskets
*MSD Pro Billet Distributor
*MSD Coil Bracket
*MSD Coil
*Quick Fuel Carb
*Edelbrock Victor Intake
*Edelbrock Water Pump
*March Pulley/Bracket Set
*1 Wire Alternator
*GM Performance Aluminum Valve Covers
*PCV Valve, Breathers
*MSD Plug Wires
*Autolite Spark Plugs
*Moroso Oil Filter
*Thermostat Housing/Thermostat
*SFI Flexplate
*Internally Balanced
*Dyno Tested
*Runs on pump gas!
This engine should put out a very streetable 525-550hp depending on the customer's individualized needs. Compare that to GMPP's 430hp rating.
All for $17300.
Place an order or put a deposit down and get a free Quicktime BBC/TKO bellhousing...
