-   -   convertible top for kirkham (http://www.clubcobra.com/forums/all-cobra-talk/105546-convertible-top-kirkham.html)
redd 07-10-2010 11:40 AM
does anyone make a convertible top for kirkham 427? thanks
Rickd 07-10-2010 12:17 PM
You should be able to order it right from the Kirkhams?
Ronbo 07-10-2010 12:46 PM
If your buying the car from them I'm sure they can fit one as part of your build.
Any top that is specifically for the original cars should work, although they need a modification for the roll bars at the back and also the top as the Kirkham roll bars are a little taller than an original.
Cobra restorers sells a full kit as well as the side windows, anyone that does canvas / upholstery should be able to do the mods for the roll bars.
You'll need a pattern for the body studs (lift-a-dot posts) as well, but make sure you have the top first to verify location.
Be forwarned that most folks find the top makes the car a real b**ch to get in/out of. So much so that many rarely, if ever, use them.
mickmate 07-10-2010 08:06 PM
I use the Cobra tops made by Robbins. http://www.robbinsautotopco.com/cobra.php I make installation hardware for them.
