Wiring turn signal indicators
My wiring did not come with detailed instructions on what to do with the turn signal and high beam indicator wires. I am going to assume that i should splice the turn signal wires into the turn signal wires that go to the steering column and splice the high beam indicator wire into the high beam lamp wire?
Is that correct or am i totally off base. Thanks |
Have you seen this? Not sure if it will help you or not but check it out anyway.
Larry http://www.kirkhammotorsports.com/ma...ring_repro.jpg |
And this too: http://www.kirkhammotorsports.com/ma...merrelay.shtml
Larry |
Thanks, this was actually for a different car. Simple splice in and everything works great.
| All times are GMT -7. The time now is 07:17 AM. |
