-   -   Wire-wound resistor question (http://www.clubcobra.com/forums/all-cobra-talk/109464-wire-wound-resistor-question.html)
psychoSEAL 03-03-2011 05:09 PM
I was replacing my solenoid under the dash and found a part/wire-wound resistor (part # CP-50B DALE) that did not appear to be connected. For what purpose do these resistors work? Fan? Wipers (which are not wired) The connector tabs on the resistor do not appear to have had any connectors attached. Thanks
Outwest34au 03-04-2011 01:10 PM
Possibly it was for fan or wipers, but some old english vehicles using smiths gauges had a resistor in the fuel gauge wire also, I think this was to prevent rapid jerky movement of the needle.
Excaliber 03-04-2011 01:35 PM
My guess is that is a resistor for the ignition system IF you are using the old school point and condensor setup. Also used in some electronic applications, depending on the coil specs. Basically it drops the 12 volt primary voltage to 6 to 9 volts so you don't burn up the coil. SOME coils have an internal resistor, in which case you can hookup 12 volts direct to the coil, those without require an external resistor. Bottom line, 90% of coils require less than 12 volts or they will be damaged.
Not to be confused with the 400 volts an MSD box can suppy to a coil, thats a different animal, high volts but no amps to speak off, plus a special coil required.
I have such a resistor on my ERA firewall and have actually used it the few times I was experimenting with the old point style distributors. Which I could never get to work well beyond about 5,500 rpm.
They are usually ceramic body because they can get pretty hot depending on how it's used and for what. Like a heater fan speed control application for instance.
psychoSEAL 03-04-2011 07:23 PM
Thanks for the response. I think it was for the wipers which have never been hooked up. I'll know in a few weeks when I get her out on the road.
