Old 04-01-2011, 09:21 AM
Ralphy's Avatar
Default 3/4" DD Shaft
What is the recomended minimum shaft size for manual steering? Does 3/4" DD make it? I'm thinking 3/4" splined?
Ralphy
Old 04-01-2011, 10:01 AM
stallion112's Avatar
Cobra Make, Engine: Kellison Stallion, 429 SCJ,
3/4" shaft has been the industry standard for US applications since the 1970's. If the rest of the system such as U-joint angles, connections, bearing supports, etc. are properly designed, this shaft size is more than sufficient for a manual steer vehicle in the weight range of a Cobra.
Stallion112
Old 04-01-2011, 10:11 AM
mreid's Avatar
3/4 DD is perfect for the shaft, you will only need a 3/4 DD to splined u-joint for the connection to the steering rack. There is a different sized spline depending on a power or manual rack.
RCR GT40 SOLD to Fast 5
Kirkham #690 289 FIA
Old 04-01-2011, 10:20 AM
Ralphy's Avatar
Thanks Guys,
Just read on Flaming Rivers site 15 degree max angles work best. I also started thinking the rack input shaft is only 9/16".
Power steering has also been standard since when?
Old 04-01-2011, 01:30 PM
mreid's Avatar
Hey, some people even use, God forbid, Chevy engines!
Old 04-01-2011, 04:37 PM
mickmate's Avatar
Borgeson, Flaming River and all use 3/4 as their standard. They are also available in aircraft aluminum 3/4. I like steering to be steel personally. Make sure you put a groove or indent with any u-joints to stop them pulling apart. There was a guy on here a couple of months back that suffered from DD (dangerous disassembling) problems.
mickmate
http://www.actoncustom.com/
Old 04-01-2011, 06:47 PM
Speedway Motors sells a stainles steel (polished) 3/4 dd shaft that looks good....
Old 04-01-2011, 07:12 PM
Ralphy's Avatar
Nick, yeah I have seen to many set screws loosen. Thanks Bob.
