Noise/Rattle Steering Column Area
I've got a Noise/Rattle coming from the Steering Column Area (ERA) when I go over rough patches in roads - sounds like something is hitting on another surface - I'm clueless as to what it could be. The rougher the road, the more noise.
Any ideas as to what to look for? |
I had a similar noise, and I found the aluminum baffles on either side of the radiator at the top were hitting on certain bumps. I put some rubber bumpers in between, and the noise disappeared. Good luck
I'll look into that, thanks.
I have a Backdraft and had similar noise that I thought was comming from the sterring wheel area, but could not locate where it was coming from.
I gave up looking thinking it was inherent to the car. I decided to replace my pedals with billet alum and apperently the noise was coming from the gas pedal assembly. No more knocking....... Who would have thought.......... am |
Hmmmmm....Thanks, I'll also look into that.
I had a noise which I thought was coming from the steering area. I checked the u-joint on my steering, it was good and tight.
I ended up checking my ball joints. I have stamped upper and lower A-arms..I know crappy setup.. My lower A-arm ball joints were way loose. I tightened both the driver/passenger side and the sound went away. |
What frame number ?
What rack do you have, the Subaru or Mustang II ?? What steering column Triumph or ERA?? |
| All times are GMT -7. The time now is 06:17 AM. |
