-   -   Clutch Master Slave Drive (http://www.clubcobra.com/forums/all-cobra-talk/115823-clutch-master-slave-drive.html)
Madrush 05-30-2012 05:53 PM
Need to know where to find the one on my superformance. They don't carry that part and I've had trouble matching it up with any others at various part stores...Any help would be great...Cobra down till I find one.....
CWizard 05-30-2012 07:12 PM
Hello Madrush,
If you can post some pictures of the slave cylinder it will help a lot, and someone here may be able to identify it. In the meantime, have you looked here: New Page 1 ?
Also, I'm assuming you're talking about the slave cylinder, but if not, the above link also give master cylinder info. In addition, slave cylinders are not SPF supplied parts and are selected by the installer. Maybe you can contact whoever did the engine/transmission installation for your car and ask about the slave cylinder?
Good luck,
Jerry
jhv48 05-30-2012 07:58 PM
Most use the 7/8" pusher slave from a 1988 Isuzu p/ u.
Napa or autozone will have one for you. If yours is different, just remove it and take to your local auto parts store for a match.
Voyager 06-01-2012 07:16 AM
1988 Isuzu p/ u rings a bell. Make sure you get the alignment correct or you’ll be redoing the job shortly.
