Old 06-10-2012, 04:45 AM
BAsque1's Avatar
Default Antenna hole plugs for fiberglass bodies
My Cobra has an old automatic antenna which does not work anymore and I would like to cover the hole with an antenna hole plug, however, the thickness of the fiberglass does not allow it to work well. Any suggestions of sources of these plugs will be appreciated. Black plastic polyurethane is ok with me, tha car is black.
Tks
Basque1
Old 06-10-2012, 05:10 AM
Ron61's Avatar
Post
They probably wouldn't match your black well but I went to NAPA when I had my Cobra and got a box of Black Rubber Frame hole plugs I think is what they called them and they came in all sizes and lengths. Just a rubber plug with a wide top kind of like a washer on a bolt. Also if you don't plan to use the antenna again you might have the hold fiber glassed over and match your paint perfectly. Maybe go to some Auto parts stores and talk to them about what they have.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 06-10-2012, 05:15 AM
BAsque1's Avatar
Ron:
That's what I am looking for the ones with the bolt under, I will check them out.
Tks buddy
Lou
Old 06-10-2012, 11:04 AM
Rick Parker's Avatar
Have you considered plugging the hole with layers of fiberglass and having it spot painted? Done correctly it will not be recognizable.
Old 06-10-2012, 11:26 AM
FWB's Avatar
FWB FWB is offline
Originally Posted by BAsque1 View Post
Ron:
Tks buddy
Lou
McMaster-Carr
Lou, use their search, there are alot more styles
Fred B
Old 06-10-2012, 11:37 AM
bobcowan's Avatar
Look min the plumbing section at Lowes or Home depot. They sell metal hole plugs for sinks, that simply plug into the hole. Easily painted. Seal with silicone.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
