November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 07-14-2012, 01:35 PM
Default Superforamce
Have not started my cobra in about 3 weeks. Car will crank fine but won't start. Any suggestions?? I can see the gas in the carb and waited 5 hours in between try's in case it was flooded. I have upgraded the ignition to a al-6 msd.
Old 07-14-2012, 01:36 PM
Remove a spark plug and hold it up to a metal surface and see if you are getting spark.
Old 07-14-2012, 02:40 PM
Silverback51's Avatar
Did you make the MSD change since the last time it ran?
John Hall
Old 07-14-2012, 02:49 PM
No, have changed anything since I parked it last
Old 07-14-2012, 07:45 PM
Do you smell gas when trying to start it after a few moments?
Jim
Old 07-14-2012, 09:17 PM
Have you tested for spark?
Old 07-14-2012, 09:30 PM
Slick61's Avatar
Cobra Make, Engine: BDR #89, KCR aluminum 427 windsor
choke?
R. Smith
Santa Clarita, CA
BDR #89- KCR aluminum 427 windsor, TKO-600
Old 07-14-2012, 09:55 PM
Cobra Make, Engine: Unique Motorcars 289 FIA street version
What kind of dizzy are you using? Points, unilight, magnetic pickup? Have you tried bypasssing the CD box to see if it will start?
Old 07-16-2012, 10:10 PM
Cobra Make, Engine: Superformance #2689 Roush 427R TKO 600
Check the coil, we recently had one with the same problem and changed boxes and still would not start it came down to the coil had died!
B i l l
