-   -   Steering wheel extention (http://www.clubcobra.com/forums/all-cobra-talk/128311-steering-wheel-extention.html)
RET_COP 03-24-2014 06:25 AM
I have a Lacarra steering wheel that is to far away and would like to have it closer. Lecarra says they don't make extensions which surprised me. Does anyone have a suggestion. I looked for extensions but could not find any for the pattern.
Thank, Lou
G_Edmonds 03-24-2014 07:15 AM
Is it possible to move the column forward and have a new shaft made?
indianamoon 03-24-2014 09:06 AM
Entension
Lou,
If you aren't able to find one, let me know and possibly I could machine one up for you.
Pat
RET_COP 03-24-2014 10:48 AM
I was lookin for a bolt on piece.
Thanks for the offer Pat. I'll let you know. Just a 4 inch hub adapter, you would think it would be a common request for Lacarra.
RET_COP 03-24-2014 11:08 AM
Could it be that the extra long quarter inch fine thread bolts pose a safety problem in a hub adapter?
Rick Parker 03-24-2014 12:06 PM
Move the seat?
RET_COP 03-24-2014 12:23 PM
I just put in the Kirkey vintage seats and the back is against the frame which gives it good support. The pedal placement is good and my legs aren't bent too much, any more and they will hit the bottom of the steering wheel [another reason for the steering wheel to be closer, to give me more room above my legs]. I have long legs.
indianamoon 03-24-2014 01:27 PM
Yup, meant that I could make you a bolt on piece.
Do you have the nine bolt hub? How far are you thinking about moving it?
Pat
RET_COP 03-24-2014 03:01 PM
2 Attachment(s)
Pat, 2" will work for me. I have the 9 bolt pattern.
I called Billet Specialties, they don't make them and he was at a loss for suggestions. He said they don't really have a big demand for them.
The 1/4 x 3/4 fine thread screws with the counterbore heads would be a slight problem. I could use studs with washers and fancy nuts.
RET_COP 03-24-2014 03:12 PM
2 Attachment(s)
Here is last weekends project
cab 03-24-2014 09:41 PM
take your wheel to machine shop and ask them to make a spacer, look on line mc master car get some longer screws, I made my spacers for my hurricane.
joyridin' 03-25-2014 04:06 AM
You can get the screws in stainless steel anywhere in that size length, but they usually have a Phillips heads instead of a socket head. You might have to dig a bit to find the socket head style.
Start with Ebay.
indianamoon 03-25-2014 04:14 AM
spacer
Looks like the same wheel that I have on my B&B. If you can't find it elsewhere, just pm me. BTW, if I do it, you will be sending it to a machine shop.
Pat
347stroker 03-25-2014 06:09 AM
I have found that my local Ace Hardware usually has an amazing selection of nuts bolts and stuff in stainless. If you can't find it pm me. We have A+A Fastener here in Baltimore. If they don't have it it doesn't exist. Tom
Turbonut48 03-26-2014 01:29 PM
Does Lacarra make a deep dish wheel?
The Nut %/
RET_COP 07-17-2014 01:50 PM
4 Attachment(s)
To follow up on my quest to find a spacer for Lecarra steering wheels. The special thanks goes to Indianamoon. Pat made me a spacer of very good quality that looks great and fit perfectly. Pat, I hope you saved the XYZ s on this product as it's the only one I could find in the country.
Again, Pat thanks so much for you fine workmanship and frequent emails to keep me updated on the progress of the spacer.
Lou
