November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 06-25-2014, 10:19 AM
indianamoon's Avatar
Cobra Make, Engine: B & B 289
Default Need help with side curtain ferrules
The center side curtain ferrules on both doors of my B&B are loose, rattling, and starting to gouge the paint. They both need to tightened up and I can't figure out how to do that.
Have talked to Barry McGill and he told me that, at the time my car was built, they didn't use ferrules, so they were added by somebody else at a later date. There is a steel bar inside the door that prevents me looking inside the door and up at the bottom of the ferrule to see how they are attached.
Both ferrules will pull up and down about 1/16" and they will both rotate a few degrees, but won't come out. The ferrules appear to be a lathe turned part with no wrench flats, screwdriver slots, hex, or any other way to turn them.
Gotta get 'em tightened before they wear a hole right in the glass.
Anybody have any ideas before I drill some holes and invest in a borescope?
Old 06-25-2014, 12:17 PM
kevins2's Avatar
Cobra Make, Engine: ERA #795 427 S/C completed Jan. '14 - '68 FE 427 side oiler
Hmmm...if they were added later as you said that implies there must be a way to get inside the door. Most ferrules are held on by c-clips or some other type of retainer on the bottom so I'd look harder at gaining access. If you're able to do that, this is what I did:
My ferrules were a bit loose and I didn't like the metal to paint contact, so I picked up some 7/16" neoprene washers at Home Depot and cut them to size (slightly smaller diameter than the head of the ferrules. They were thicker than I wanted so I also used the side of my grinding wheel to make them wafer thin - so, you can't see that there are washers. I also used o-rings on the inside. When I reinstalled them I was able to compress the o-ring a bit against the c-clip for a nice tight fit.
Kevin
"Anyone who drives faster than you is a maniac and anyone who drives slower than you is an idiot" - George Carlin
Old 06-25-2014, 05:52 PM
DanEC's Avatar
Do the ferrules go all the way through and come out below on the inside skin of the door? Or do they just seat in the outer skin of the door? If they don't go all the way through both door skins it will be difficult to take the play and movement out of them.
