-   -   LSD Gear Ratio (http://www.clubcobra.com/forums/all-cobra-talk/138647-lsd-gear-ratio.html)
CUZECAN 06-19-2017 03:38 PM
LSD Gear Ratio
What is a good set up? Will hardly get driven on Highway. Coyote NA Motor. #1369. I believe it came with 3.45. Looking for recommendations.
cycleguy55 06-19-2017 03:58 PM
There are a lot of variables here: tire size, transmission output ratio, and desired RPM (related to engine power band). You might want to plug your data into one of the gazillion online calculators to start. Try the 'Transmission Ratio RPM' calculator here: https://www.ringpinion.com/calculators/Calc_RPM.aspx
pgermond 06-19-2017 04:56 PM
What transmission?
Ron61 06-21-2017 09:55 AM
Also what tracks will you be running on? I know several people that have more than one set of rear end gears and they change them depending on the track they are going to.
