-   -   Engine mounts: Robert Pond alloy block (http://www.clubcobra.com/forums/all-cobra-talk/141271-engine-mounts-robert-pond-alloy-block.html)
AC Ventura 08-01-2018 01:07 PM
1 Attachment(s)
Hi guys,
Would anybody like to share the mounts they are using with the above block?
As you may know it has 4 x 7/16 tapped holes each side. I bought the flat rectangular 2241 & 2240 3 hole mounts but they don’t fit. Plus they are stepped and the machining is flat.
I know from one respondent that a custom longitudinal bush type arrangement is available, but not sure how that gonna work when I have lift under the bellhousing to slide the TKO in.
Im sure this is a well trodden path would be more than grateful for some real life pix and recommendations.
strictlypersonl 08-01-2018 01:37 PM
We currently use 2-bolt mounts, 31-2222 and 31-2223 on our Pond installations. It is stepped also. I didn't do the installation, so we may have had to shim it on that block. On our very early cars, we used the 3-bolt ones that you have, but never had to shim for the original iron FE block. (The stands on the chassis are not the same between the 2-bolt and 3-bolt mounts.)
RockBit 08-01-2018 02:17 PM
I used the 31-2222 / 31-2223 mounts for my Pond aluminum FE in an ERA. I did not need to use shims, and have had no issues. I can raise the back of the block when installing or removing the transmission.
Sorry, but I don’t have good pictures.
jwoodard 08-01-2018 04:38 PM
I used polyurethane mounts from Craig's Cobras on my Genesis block. Should be fine for the Pond block as well. Here's a link: https://www.craigscobras.com/parts/mounts/index.htm
:3DSMILE::3DSMILE::3DSMILE:
Varmit 08-05-2018 09:35 AM
That's what I used on my Pond 482
