1Likes
Post By RockBit
02-21-2019, 08:58 AM
BC
what angle is your windshield?
Hi,
Some windshields look too upright and some just right.
What angle is your windshield from 90 degrees straight up?
I am thinking 40 to 42 degrees, what do you think? 45 degrees looks like the fitment at base is off.
Thanks.
Perry
F5 cobra Mark 4 roadster, **SOLD** Ruby Wine Red with pearl,
dual 2" roll bars, warmed up 302, Edelbrock AVS carb and heads, E Street aluminum Heads, Comp cam and roller rockers, AOD, 4.10 Eaton Posi, Power Baer/disc brakes, block hugger headers, 2 1/2" under car exhaust, F500 18" black spoke wheels.
02-21-2019, 09:49 AM
sk
Cobra Make, Engine: canadian classic roadsters
your car has the factory cowl bar in place so it should have the holes already and a guide to set the windshield at the proper angle as per most classic roadsters cars
02-21-2019, 10:26 AM
This is the FIA, the 427 cars, like mine, are a degree or two more.
02-21-2019, 12:30 PM
AL
Put it where you want it.
Move it and clamp in place, step back and look at it. When you get it were you like the looks then bolt it. May have to drill two to four holes. Not hard to do.
we short guys can rack it back a little. Tall guys need it more up.
02-21-2019, 02:47 PM
Just for reference I set mine at 53° to match the soft top that I never bought.
Frank
FFR - V8, Manual Trans, PS, Inop Wipers, No Radio, Gas Mileage so-so
02-21-2019, 03:43 PM
I would have thought 53° would be too much, but that looks good. Dwight's right, eyeball it to whatever looks right.
02-21-2019, 06:11 PM
Tx
Cobra Make, Engine: Classic Roadster, 408 LSX
I installed mine the way the Classic Roadster manual described. It is definitely more upright than everyone else's that I run with. Kind of annoying but I haven't done anything about it yet.
I've spent most of my money on cars and women. The rest I wasted.
02-21-2019, 07:03 PM
WA
Perry, I just checked the angle of mine (Factory spec.) is set at 48degrees. Look's just fine to me. Cheers Tom.
02-22-2019, 08:35 AM
Decades ago I saw a diagram with a distance from the top of the windshield frame to the door edge that made getting the best, or darn good angle, easy. Of course, I can't remember what it was, but I'm thinking someone out there will know.
Karlos
02-24-2019, 09:37 PM
MA
OE (center line) of the windshield posts is 55deg. (off horizon/ 35deg. off vertical) making the center of glass approx 45. You can go more towards 40deg for that FIA look if you like ; ) I am a fan, but consider if you will be fitting a top later on which may not jive to an abnormal windshield angle.
-J. James
M. Krause
1.508.944.3368
02-26-2019, 05:20 AM
My measurements from the photo show 46 degrees on the glass.
03-09-2019, 08:47 PM
Btw digital angle gauges are cheap and a great tool to have around. Harbor Frieght even sells one.
03-10-2019, 05:31 AM
Cobra Make, Engine: Myself/Body from CSX-2575 & hand built Birdcage
6S1941
Allied 289 Slab Side
73 2.3 turbo pinto
03-10-2019, 05:58 PM
The ride height settings front and rear on your car will affect the measured windshield angle a bit.
Chris
03-11-2019, 12:32 AM
WA
Good thought ! I run a 275-60-15, where most other's here run the 295-50-15 rear's. Would that make my angle a touch different, maybe? Mine was zeroed out, on the cowl, then measured on the windscreen, so maybe not? I'm confused, which doesn't take to much, now-a-day's  ???
03-11-2019, 07:43 AM
If you zeroed out on the cowl then you are measuring the angle with respect to the car. Ride height will not affect the angle.
Ride height only affects the angle if you measure with respect to horizontal or vertical, such as with a bubble level.
Chris
03-11-2019, 02:16 PM
Ut
We set our windshields at 45 degrees.
