-   -   Help With Cobra Tail Light Wiring Needed (http://www.clubcobra.com/forums/all-cobra-talk/142667-help-cobra-tail-light-wiring-needed.html)
Jim Coleman 08-13-2019 08:19 PM
I am in process of installing a wiring harness in my Arntz.
The tail light assemblies are one piece units and only have 2 wires.
The wire colors are green with a white stripe and yellow with a white stripe.
Since there are 3 wires going to each tail light -- brake, turn signal & park -
how are they wired ?
Thanks,
Jim
ALF 08-14-2019 12:04 AM
Hi Jim
If you use the DB 10 relais and the Lucas L542 lights BREAK and TURN SIGNAL is the same wire.
- park light (5W on two wire bulp)
- break/turn signal (21W on two wire bulp)
- ground
Jim Coleman 08-14-2019 02:12 AM
Thanks, Alf-
Which wire is the brake lights/turn signal ?
Jim
strictlypersonl 08-14-2019 05:05 AM
Originally Posted by Jim Coleman (Post 1465573)
Thanks, Alf-
Jim
I wouldn't count on any consistency relating colors to filaments.
Turn the parking lights on and connect the live lead at the rear light to the wire of the dimmer filament.
Jim Coleman 08-14-2019 04:20 PM
What I did was install removable bullet connectors so I can change them around if needed after the harness is completely installed.
ALF 08-20-2019 03:57 AM
I've the 289 wire colors in use.
Red = RH/ LH Tail Lamp
White and Puple = LH Stop Lamp
White and Brown = RH Stop Lamp
Black = Ground
Thanks, Alf-
Jim
Jim Coleman 08-24-2019 04:06 AM
Thanks, again Alf
Jim
