Engine expansion when hot?
I wonder if anyone knows the answer? Scenario; Windsor iron block aluminum heads, as the motor goes form ambient to what 180+ degrees F, I would submit that the heads would get taller and wider (a minuscule amount)?
Resulting in the intake (which also gets wider) being “pinched” in the valley tighter? |
Here is a posting I did about the effect on an engine block and heads as the engine comes up to operating temperature. The focus is on head gaskets and why the recommendation to retorque after an initial heat cycle.
The math and the thermal expansion phenomena occur in all directions not just one so the model can help you to actually measure what you are interested in. Because everything is bolted together when cold the similar metals will exhibit similar geometry after warm up. The disimilar metals will not. Here is the link => Effect of Engine Warm Up on Engine Dimensions Ed |
This article will help to troubleshoot the gap mismatch that you are fighting and show if and where your intake needs milling.
http://www.hughesengines.com/Upload/...NGJULY2015.pdf |
Iron Block and Aluminum Head Expansion Rates
The experience Patrickt is sharing with you is directly related to the differences in the coefficient of thermal expansion for the two metals. The coefficient of thermal expansion simply gives the amount of growth per degree of temperature increase that a particular metal will exhibit.
The increase and then subsequent decrease in valve lash is attributable to the differences in the thermal conductivity of the two metals. Aluminum has a higher thermal conductivity than cast iron which means it will expand more and initially faster than cast iron. The lower thermal conductivity and lower coefficient of thermal expansion for the cast iron means the cast iron will expand less (but it will still expand) and it will take longer to see this expansion because it's thermal conductivity is less than that of aluminum. Eventually when both metals have had sufficient soak time to normalize their temperatures and realize their maximum expansion for the heat energy absorbed, the cam and valvetrain will have quieted down again. The reduced lash that has quieted the valve train is directly attributable to the cast iron block's expansion after it's operating temperature has normalized with that of the cylinder head. Ed |
https://www.engineeringtoolbox.com/l...ents-d_95.html
aluminum is about 22 and cast iron is about 11 or aluminum grows twice that of cast iron. As for your intake, that is the beauty of a 90 deg V block. As things grow longer it is growing half the distance vertically and half the distance horizontally, per head. I think you are trying to understand your problem, but remember there are thousands of engines like yours. The aluminum/cast iron does make sealing harder, but the gaskets take the slight changes. If this were your only problem then all of these engines would have the same problem. I mentioned measuring gaps while you had the engine apart in another thread. I think you mentioned doing some checking. Each little thing adds to what the gaskets have to make up for. You have talked like the ports have been opened up to where there is very little seal surface left. Blown engines they often mil a tiny grove around the cylinder and put a wire in the grove. This bites into the gasket and can hold more pressure. Intakes I have seen rubber O-rings installed. I'm not suggesting this is "thee" solution, but it may be worth considering with some experts. Oops: I may have original poster confused with someone else. Apologies if so. |
Thanks for the very informative responses
My concern (and my conclusion) is that the intake is actually bit harder by the heads as the motor heats up. I did measure the gaps as kindly described to me on this and other forums with square results.
I’ve reassembled using liberal application of permatex aviation gasket maker. So good so far, oil level seems to be holding and she seems to be running crisper (no more two stroke fuel?)... Thanks again gentlemen for your help! Steve H 1764 |
Glad you've found a working solution, Steve. Even with the dissimilar growth rates of the different materials, if the gasket air gap that Tottuga was encouraging you to measure was square top to bottom the differences in growth would not be enough to expose an intake port.
That said, repeated heating and cooling cycles could possibly deteriorate the quality of the seal the gasket had with either or both the head and manifold. On heads and manifolds that have been port matched you will have reduced margin around each port for sealing which will provide increased opportunity for a gasket sealing failure. The easiest fix for this problem is to glue the gasket to both surfaces at assembly. I believe Brent Lykins suggested this in another thread. It does make disassembly a messier event but it also makes for a reliable gasket seal. Ed |
| All times are GMT -7. The time now is 05:18 AM. |
