| Snake2998 |
07-09-2020 03:31 AM |
High Friction Product - Good for wheel grip????
Just seen this and wondered if it would help reduce torque acting on wheel drive pins if placed on face between wheel and hub.
Anyway will buy some as it looks like a great product for the workshop.
Anybody used it and got any thoughts or experience on its effectiveness?
https://www.viborg.com.sg/products/b...friction-drops
| t walgamuth |
07-09-2020 05:04 AM |
This is an excerpt from a review. The reviews were all negative except this one.
It’s a viscous oil with some sort of metal chips inside.
| cycleguy55 |
07-09-2020 01:59 PM |
The interface between wheels and hubs are designed to be full contact. I'd be very reluctant to use any substance that could interfere with that.
| spdbrake |
07-09-2020 04:56 PM |
Valve lapping compound works well for stripped screw heads.
| t walgamuth |
07-10-2020 12:20 PM |
It should not slip unless the fastener is loose.
| Gaz64 |
07-10-2020 11:51 PM |
Originally Posted by Snake2998
(Post 1479446)
Keep this product for it's intended use only.
Any fastener in a driving scenario such as a wheel to hub face, or crankshaft to timing gear, is applying a clamping force.
The clamping force gives the friction drive.
A crankshaft keyway is quickly destroyed if the balancer bolt is loose, as example.
| Snake2998 |
07-11-2020 04:33 AM |
My question arises because my wheels are currently 5 pin drive and not six and I have upped engine power and torque significantly and worry a bit that 5 pins might not be adequate. I fully understand the need for adequate clamping etc but just wondered if their was a friction enhancing product that might act as a substitute for six pins.
Converting wheels to six pin is possible with a lot of effort as some casting/lightening holes in the back of the wheel will have to be welded shut and hubs re drilled so am looking for an alternative.
In the mean time will just monitor pin performance and health after each hard drive.
Thanks for the feedback all who replied.
| t walgamuth |
07-11-2020 04:37 AM |
Do people have trouble with these pins?
| Snake2998 |
07-11-2020 05:21 AM |
Originally Posted by t walgamuth
(Post 1479554)
Good question - I don't know - just assumed they do as it seems the preferred choice is 6 pin.
| t walgamuth |
07-11-2020 07:25 PM |
Given the idea that the clamping force is the real factor in keeping the wheel attached perhaps the main task of the pins is to center the wheel properly.
| All times are GMT -7. The time now is 06:50 AM. |
