-   -   wilwood proportion valve (http://www.clubcobra.com/forums/all-cobra-talk/144513-wilwood-proportion-valve.html)
Azhinoon 02-20-2021 06:23 AM
The car is on the lift so no street testing. Which way to turn to allow more to rear brakes. 4 wheel disk. Thanks
Tommy 02-20-2021 08:06 AM
Perhaps this link will help: Wilwood
There are many Wilwood valves. This one says the valve is plumbed into the line to the rear brakes. Turning the knob in the direction of the arrow on the knob will DECREASE pressure to the rear brakes.
Azhinoon 02-20-2021 11:41 AM
Thanks , that what i needed to know for sure.
Timinator 02-20-2021 04:25 PM
You can actually get "close" in the adjustment by having someone sit in the car and gently start to apply the brakes and adjust the valve while you physically turn the wheels. You want the fronts to the point where they can't be moved while you can just muscle the rears to move a little.
Azhinoon 02-21-2021 06:04 AM
thanks will do this.
cycleguy55 02-21-2021 09:17 AM
That method MAY work if the pressure relationship between front and rear brakes was linear, but most proportioning valves installed in the rear brake line operate to LIMIT the rear pressure, resulting in a 'knee' in the pressure curve, seen in this diagram:
https://www.brakes-shop.com/media/wy...e-figure-e.jpg
As is shown, rear brake pressure rises in a linear fashion with the front brake pressure until it reaches the 'knee', set by the control knob. After that it rises much more slowly while the front brake line pressure rises without restriction.
More: https://www.brakes-shop.com/brakeped...tioning-valves
Wilwood adjustable proportioning valve instructions: https://www.wilwood.com/PDF/DataSheets/ds488.pdf
Timinator 02-21-2021 10:42 AM
Just going by the dial proportioning valves in the racecars I've owned. These Wilwood ones could be different, especially if they're just on the rear brakes, but all the Wilwood proportioning dials I've used on racecars were front and back biasing, not just back. If this dial is just for the back brakes, then, yep please disregard.
MKS427 02-21-2021 11:02 AM
Move the bar to the side you want to increase pressure.
The 1/8" side play at the clevises is ESSENTIAL. Masters will not stroke right without out. I know ALL about this, chased a soft pedal for 3 years and 2 masters diagnosed as bad by two different mechanics. One of whom put it back together without the side play. Go to 1:10
https://www.youtube.com/watch?v=ZYK4VEOae6w
https://www.youtube.com/watch?v=NzIMlPEdtD0
EDIT: This is not Gary's setup. This applies to Wilwood pedal box with dual masters and balance bar.
