Mobil 1 Gear Lube or Red Line Rear Gear lube?
What do you suggest?
pretty much all i use in anything i own with a piston in it is filled with either Mobil products, or Redline.
I suspect they are both top of the line gear lubes, just use one in your viscosity grade, being sure to get one that has/does not have the slip addititive, depending on your diff positraction. I have a ford 8.8 with the Traction Loc, and presently run the Redline 75-90, not much gear wear for all the "abuse" i toss thru it. They are both good products, |
I used Mobil 1 in my IRS and it made noise. It Didn't make a whiney or whirring sound but I could hear it working.. I went back to Valvoline 90 wt for the powr lok.
| All times are GMT -7. The time now is 09:57 PM. |
