-   -   Brake lines - 3/16" versus 1/4" (http://www.clubcobra.com/forums/all-cobra-talk/49457-brake-lines-3-16-versus-1-4-a.html)
DaveR 01-19-2004 08:37 PM
I getting ready to install brake lines. Should I use 3/16" or 1/4"? The SPF's that I have seen use 3/16", and I assume that is the gold standard.
Rodney 01-19-2004 11:27 PM
brake lines
The braided stainless flexible lines are -03AN and the hard lines are 3/16
If you would like to go the extra mile, look for 304 stainless steel tubing that is seamless and has a wall thickness of.028 with this tube you may use a single 37-degree flare with a tube sleeve and tube nut assembly, looks very nice.You will find it all at www.GODMANHIPERF.COM Hope this helps. Rod
