Old 02-26-2004, 08:23 AM
Cobra Make, Engine: SPF 1498, 351 stroker
Default oil leaks and aluminum fittings
For whatever reason I am having a heck of a time with leaks at the oil fittings entering the block (stainless lines from cooler to block). They are loosening up over time and creating small leaks and making a mess. I’m considering a bit of locktite. Any tricks or suggestions I should know of?
Old 02-26-2004, 10:02 AM
Mr.Fixit's Avatar
The pipe threads need some gooey liquid teflon sealant on them, then torque em down good and tight. If it is the flare fitting tapered cone part that is leaking, they make aluminum crush washers that help make the seal 100% tight.
Old 02-26-2004, 12:01 PM
Thanks fixit. I'll give it a try
Old 02-26-2004, 01:26 PM
Rick Bagley's Avatar
Cobra Make, Engine: Unique 427 S/C, Red w/White Sripes, 427 SO, 4 speed Top Loader
If its the threaded part then Permatex Aviation Sealant is the ticket, good for oil, and fuel lines. Available at NAPA.
Eliminator
Old 02-26-2004, 04:41 PM
Rick Parker's Avatar
Do the crush washers work well? I too have a minor leak at my oil cooler and I am afraid to tighten the nut on the fitting any tighter since I can not get a wrench on the base of the male fitting on the oil cooler, and do not want to fracture the solder/brazing that attaches the male port on the cooler.
Old 02-26-2004, 05:01 PM
Mr.Fixit's Avatar
they do work well, the two places I used them on cobras:
flares on the stainless hardline for fuel
oil cooler
