| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
06-21-2007, 08:28 AM
GA
Cobra Make, Engine: Unique 427 SC, Southern Automotive 427W Stroker
In serious need of 16" tires
I'm in a world of hurt for some tires that will work with my 16" Compomotives. Anyone have any suggestions? I've searched Tire Rack and everywhere else I can think of for some replacements for my 255/50/16s front and 275/50/16s rear. I can find 295s in that same BF Goodrich TA, but not a matching 245 or 255 tire. I would rather not replace the wheels as they are perfect for the car. But I will do what I must to get back on the road.
After a good hard ride.....oil pressure is over 50, temp is below 190, she idles and no new dents. LIFE IS GOOD!
06-21-2007, 11:37 AM
FL
Dan Wulff
06-21-2007, 01:23 PM
Cobra Make, Engine: SPF 2387, 427 W, Webers
Hoosier
Hoosier makes some road race and auto cross tires in alot of 16" sizes. My Porsche runs 16" rims and 225 50 front and 245 50 rear. I think they may have exactly the size you are looking for. The downside is they are dry tires with only circumferential (sp?) grooves. They pick up every thing and throw it up at the fender like a sling. Not so good for a glass body car. With the right fender protection and dry only driving you would have sticky tires that all the 15" guys would die to have. The mileage is not too bad for a car which you may put 2-5k/yr on. Check them out.
06-21-2007, 02:25 PM
Cobra Make, Engine: Ex CSX3327, & AK7113 AutoKraft AC MK IV
Look at Dunlop SP Sport 8000, come in both sizes, not stupid sticky, but work well and have a good look
06-21-2007, 03:34 PM
GA
Thanks guys. I'm starting to stress here. I've spoken to Hoosier, Coker, BF Goodrich etc. The ebay tires are all the same size and I need wider rubber for the rear. I've got to get the front and back to match. BF Goodrich can put me in a 295/50/16 and a 265/60/16. I think the back ones will work as from what I can tell, the height difference is minor compared to the existing 275/50/16s.
06-21-2007, 07:17 PM
MD
Cobra Make, Engine: Unique 427 S/C 427 FE S.O. 484 cu in
Hey Tony,
I saw your car at SA. Looked good. Susan said that it was fast. What say you?
06-22-2007, 03:45 AM
GA
Tony, thanks. I don't have anything to compare to, but she's capable of raising my heart rate once in a while. As is usually the case with major surgery, she's better coming out than she was going in. But I still have a sever vibration issue to resolve. Hopefully some new rubber will solve that.
06-22-2007, 05:28 AM
MD
Are you having that 60-65 MPH shimmy? Good rubber usually solves that.
You might want to call John Kerr @ Crendon Replicars in England. He run 16s on his cars. Ask Susan for his phone number. SA builds engines for him.
Good luck
06-22-2007, 11:58 AM
GA
I have put a plan in motion. I ordered the BFGs, which should arrive at NTB on Monday. Someone will ferry the tires to J3 Motorsports where they will be mounted, ballanced and put on the car. They will also set up the suspension, making any suspension adjustments that might be required due to the tires being slightly larger (unlikely). And finally (knock on wood), my vibration problem will be solved. As a result of the pursuit of this ever elusive gremlin, I wil have a new car!
06-22-2007, 01:08 PM
MD
Cobra Make, Engine: Unique, 427SO, it runs
Tony, I hope you win the lottery by drawing 4 round BFGs (or at least round fronts). I could never completely get rid of the shimmy with them, and it wasn't until I switched to Yokos that it was gone once and for all. But, I am running 15s.
Clay
06-22-2007, 01:13 PM
MD
New rubber is always better. Good luck with it. You might have to think about going to 17s.
Save up for some Vintage 17" knock offs.
I am thinking, unless they do something about supplying good 15 inch rubber, I might have to have a spare set of 17s. With my car I will powder coat the wheels black.
06-23-2007, 06:20 AM
GA
You know it's funny, but after all my car has been through during the last few months, out of sheer desperation, I dropped her off at a local shop - J3 Motorsports. They're basically a Porsche racing team who sets up / modifies cars for racing. They've already found a few issues that could effect my ride quality, and none related to tires.
06-23-2007, 07:09 AM
MD
Well that is god news. Have you ever done a 4 wheel alignment?
06-23-2007, 08:02 AM
GA
I took her to Granturismo East last year for a hyper-precision balance and alignment as I had out of round issues with one or two tires. They stood up to their reputation and did a stellar job. The guys at J3 have a nice alignment rig as well. I'm thinking about at least changing the rear tires from the current 275s to the new 295s I have coming. My tires are so old. The found a really bad Ujoint in my drive shaft and a coupld of wheel bearings are bad. They also plan to take up some slack in my rear wheels as they insist they're too loose.
06-23-2007, 10:31 AM
MD
I am running 295/50s on the rear but they are 15s.They are 26.5 inches tall.
Wheel bearing can effect steering for sure. Bad u-joint? been hammering it little to hard?
Let us know how she feels after everything is done.
