-   -   Which Tach with MSD 6AL ? (http://www.clubcobra.com/forums/all-cobra-talk/81879-tach-msd-6al.html)
rbray 08-30-2007 01:02 PM
Hi Guys,
Does anyone have a recommendation for which tack to use with an MSD 6AL ?
Curt C. 08-30-2007 04:50 PM
Most tachs will work with that box. Which tach do you want to run?
rbray 08-30-2007 05:12 PM
I have need to replace my SW. Somehow I manged to fry the **** thing and I need a replacement.
It worked fine for a while until I had a problem ( my fault ) with the MSD. After I replaced the MSD box the tach never worked again.
rbray 08-30-2007 05:40 PM
Come to think of it, I could have rewired the tach wrong.
Maybe someone could help me out.
Here are the the lables on the treminals of the unit:
SIG
BATT
GND
and a seletor swithch with the following positions.
A 4cyl
B 6cyl
C 8cyl
D Alt 12 pole
E None
I have the tach wire from the MSD connected to the SIG terminal
The BATT terminal has switched 12V on it and the ground is grounded on the aluminum dash ( like all of my other gauges are).
The needle either wanders or settles on 7k rpm.
Any Ideas?
Thanks
Curt C. 08-30-2007 06:57 PM
Sounds like it could be a bad ground. Check the ground and connections. Or, the problem with the earlier MSD box could have damaged the tach. Check your ground and then go from there.
MaSnaka 08-30-2007 07:14 PM
Call Stewart Werner tech support. They can walk you through a diagnosis.
915-593-1965 ext. 154
Good luck, John
Tom of VA 08-30-2007 08:31 PM
Sometimes you may need a MSD tach adapter. I also needed a capacitor to run my tach. Call MSD there tech support is very good.
