| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
02-17-2008, 07:38 PM
NY
Driving in rain
I'm a new owner of an SPF and and as this is my first real sportscar of this caliber, I have is about driving in the rain.
Do I have be careful about getting water in the hood scoop and getting my engine/air filter wet? If I am out inthe rain, should I put a piece of foam or something in the scoop to stop that from happening?
Just wondering.. Thanks
Steve
02-17-2008, 07:44 PM
CO
Depends on the type of air cleaner you have. If it's an open top element, like a K&N filter rop, then water could be a problem. You can buy a Dry Sock from K&N that works well for this. If your air cleaner has a solid top, like a standard round chrome, then it's not really an issue.
The only real issues are visibility and traction.
02-17-2008, 08:16 PM
tx
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
I think firstly, don't drive in the rain.... But if you do get caught in the rain, small ammounts of water won't hurt your engine at all. It's a known fact that you can pour water directly into your carb while the engine is running to knock off excess carbon. Botom line, water won't hurt your engine.
" It ain't no big deal"
02-17-2008, 08:53 PM
Beam Me Up Scottie
MA
Warren
02-17-2008, 08:55 PM
NY
Cobra Make, Engine: Superformance MKIII #887, drive it a lot!
Steve,
I have put a lot of miles in the rain with my SPF. I currently run the open top K&N, and haven't seen much of a difference in the rain from running the Cobra style oval filter I used before. I have driven from just outside NYC back to Breesport in the rain (over 5 hours of highway driving) with the open top K&N. The engine runs richer after 15 or so minutes of heavy rain, but then runs about the same (I have a Ford Motorsports 351w/385hp). My next setup will not have an opening facing the scoop, or possibly I will try a turkey pan to try to keep the filter element dry. I did have a run once in very heavy rain where I had to keep the engine revs above 3,000 - otherwise I would get a misfire from the rich condition. That, coupled with poor visibility (not just for me but everyone else on the road) made for a difficult drive.
The biggest factors are visibility, getting wet, and traction (not neccesarily in that order :-)
I use Rain-x, which helps a lot. I have run in the rain with the convertible top and my hardtop.
Either way, you will get some water inside during heavy rain. The hardtop is much better, and if I took the time to seal the top to the windshield, I may even be able to stay dry. Remember, these are replicas of a 60's sports car with side curtains. There will be some gaps (door opening, side curtain slide to fixed window, ect), although there are some good SPF tech articles available to show how to add extra seals. I keep a towel behind the seat, and lay it across my lap when driving in the rain :-)
The SPF has a decent defroster, which is a big help in the rain.
Traction. Now that's an issue! Let me just say that you have to pay extra attention to smooth throttle application - both getting on AND off the pedal. I like to drive in the rain for the excitement. It will definately keep you on your toes!!!
Hope to see you and your SPF some time this summer!
Jim Kellogg
Breesport, NY
02-17-2008, 09:56 PM
CA
I got caught in the rain twice and the only problem that I had is that I got a little wet.
Seriously, I wish the top on the Superformance was little easier to assemble. I guess the best bet is to try and run for shelter or throw the tonneau cover on until it stops raining.
BTW - I should have mentioned that my left knee got totally soaked as water ran through the door jam...my pants acted like a sponge.
Doug
