Exhause flanges
http://www.clubcobra.com/forums/all-cobra-talk/86595-exhause-flanges.html)
| stefan h |
04-03-2008 12:06 PM |
Exhause flanges
:)Hi, can anyone help? I am looking if there are drawing available of the exhause flange to bolt on my AFR 185 heads. I need to have them made here and make my own headers.
Thanks, regards from Sweden
| greg schroeder |
04-03-2008 01:20 PM |
You might be able to use the AFR recomended gasket.
| stefan h |
04-04-2008 09:11 AM |
That may be an idea, I was thinking to find an AutoCad drawing so I can have the steel flanges cut out by waterjet
| strictlypersonl |
04-04-2008 10:31 AM |
Do the AFR heads have a narrow and/or wide bolt pattern? I've got a drawing derived from a set of Earls gaskets with the narrow pattern. Port size 1.62"H x 1.125"W.
If you give me the port size and its relationship (height-wise) to the bolt holes, I might be able to whip up something.
| vector1 |
04-04-2008 07:37 PM |
185's have the narrow standard ford bolt pattern, 205's & 225's have both standard and wide.
| stefan h |
04-05-2008 11:55 AM |
%/I will chech the bolt pattern and port size tomorrow. I apriciate all your inputs hope we find a solution.
Anybody else fabricating their own headers??.
(Got a parts shipment from Summit and my wheels today, spring is here!)
| stefan h |
04-06-2008 11:37 AM |
The port size is W 1.33" by H 1.37" bolt pattern is 2". I measured in milimeter and converted to inch.
| strictlypersonl |
04-06-2008 03:34 PM |
Is the port centered vertically on the bolts?
With only 0.335" between the edge of the port and the center of the bolt, there isn't much room for a wrench. Generally, even with the narrow port, the tubing flares out from the port but is dented in to clear the bolt head.
http://www.erareplicas.com/fiaman/engine/afr_port.jpg
| stefan h |
04-07-2008 01:15 AM |
Thanks for the input. No it is not even centred, I am on travel a couple of days but will take more measurements and photo diring the week
| Three Peaks |
04-07-2008 06:33 AM |
Have you checked to see if AFR, Summit, or Jegs (among others) may sell the flanges? I have a friend who can probably sell you the flanges with stubs attached if you would like to go that route?
Bob
| stefan h |
04-07-2008 08:10 AM |
Bob, I have not checked by Summit or AFR. Keith Craft have build my engine, the heads are CNC machined so I am not sure if the port size is standard. how much do your friend ask for e set?
| Three Peaks |
04-07-2008 08:30 AM |
Stephan,
I would need to know the exact size of your ports and relationship to the bolt hole location to see how much machining he would need to do to a standard set. A good chance the standard set will fit with little or no machining. I will check with him today and get back to you.
Bob
| stefan h |
04-07-2008 08:33 AM |
Originally Posted by Three Peaks
(Post 832170)
Stephan,
Bob
Thanks, will try to measure more exact
| 1Cobrat |
04-07-2008 08:51 AM |
I used a local exhaust supplier to help me fab my exhaust system. they do outstanding work. I/m sure if Chris doesn't have it he can point you in the right direction. Here is the link to his site
http://www.spdexhaust.com/HomeB.html
Let me know how it goes.
| Three Peaks |
04-07-2008 10:09 AM |
Stefan, PM Sent
| stefan h |
04-10-2008 12:10 PM |
Originally Posted by strictlypersonl
(Post 831981)
I try to enclose a photo for you, but my images are too large to publish here. I will find a solution.
| All times are GMT -7. The time now is 01:41 AM. |
