Old 12-14-2008, 09:28 PM
Cobra Make, Engine: Early Contemporary 427SC w/ '66 427s.o. (car built in '79) by Snow White Rods (Fresno, CA); XKE Series II front/rear suspension (AMP lower A-arms/half shafts), CWI rebuilt IRS, 4-spd Toploader, PS Engineering knock-off rims.
Send a message via AIM to gjcomb Send a message via Skype™ to gjcomb
Default Stewart Pumps
Originally Posted by CSX3183 View Post
If your post is directed to me, not only do I have many pumps, but I have SW paper work on how to install, trouble shoot etc. PM me.
CSX3183 - I sent you a PM earlier - did you receive? George
George
Old 12-14-2008, 09:52 PM
mickmate's Avatar
Wonder what reserve is http://cgi.ebay.com/ebaymotors/NOS-S...Q5fCarQ5fParts
mickmate
http://www.actoncustom.com/
Old 12-14-2008, 11:39 PM
767Jockey's Avatar
Yeah, I saw that, Nick. Problem is there's only one, meaning that even if it went for a reasonable price, which I doubt, I'll have to find another. Beat up ones looking terrible and barely working are multiple hundreds of dollars. I can't imagine anyone is going to let this go for significantly less than multiple hundreds. Then there is the pesky problem of finding it a mate. I guess I'll have to go with the Facets. I finally found a good source for Facet 59SV pumps, $99.95 each, brand new. Now I have to somehow confirm that this is the pump number I need. This is much more difficult than I ever expected it to be!
Old 12-15-2008, 08:20 AM
Default Pm
Got it, will be emailing.
Old 12-15-2008, 12:43 PM
LMH's Avatar
LMH LMH is offline
I don't think the 59SV pump is what you want. I could be wrong so anyone correct me but I believe that pump has 1/8" fittings. I think what you're looking for is commonly known as a "Red-Top" pump: 45 gallons/hour at 6-8 PSI. Part # Facet RTW506.
Where to buy one in the U.S.... I don't know but if you can find, I'd like to know.
Old 12-15-2008, 01:18 PM
767Jockey's Avatar
I found the pumps - Billy Andrews at HRE in Freeport NY sells them, less than $100 each. He says the blue tops are the ones to get, higher pressure than the red tops. Does he have that correct? Anyone?
Now, the new question is where do you get the black fabric covered fuel line, what is it called and how much does it cost? The questions never end..........I can only hope the destination is as much fun as the journey.
Old 12-15-2008, 03:43 PM
LMH's Avatar
LMH LMH is offline
BT and RT Facet pumps are both rated the same as far as GPH and PSI, so I don't know what the difference is if any.
Earls sells a black braided nylon line that's kind of similar looking to original. It's what I plan to use.
http://www.jegs.com/p/Earl%27s/751252/10002/-1
BTW, with two pumps, depending on how the two are hooked up, you can either double the pressure or double the volume.
Old 12-19-2008, 12:33 PM
Woodz428's Avatar
That type of fuel line was used for many years on European vehicles. You might check sources on that side of the pond.
WDZ
Old 12-29-2008, 01:33 AM
Sminor's Avatar
Cobra Make, Engine: Shell Valley Roadster,428FE, 2X4's; 1966 GT 350 Clone; 1968 Shelby GT-350
Hey 767Jockey,
Would you advise contact information for HRE? I could use a couple of those pumps.
Steve
Old 12-29-2008, 02:47 AM
767Jockey's Avatar
Originally Posted by Sminor View Post
Hey 767Jockey,
Steve
Sure, Steve -
Billy Andrews at HRE Motorsports, Freeport NY
(516)378-5461
Old 12-29-2008, 11:03 AM
Sminor's Avatar
Thanks again 767Jockey. I really appreciate the info.
steve
