11-02-2008, 09:50 PM
Cobra Make, Engine: West Coast Cobra
Air vent hose question
Does anyone know where I can get fresh air hose from? It is the one that runs from the front of the car to the heater box. About 4" dia. I think.
Rob
11-02-2008, 11:00 PM
Beam Me Up Scottie
MA
If its between 2 and 3 inch dia, JC Whitney ...
http://www.jcwhitney.com/FRESH-AIR-D...w?reviewflag=1
"I think" you better measure yours first.
Warren
11-03-2008, 03:15 AM
ont
Cobra Make, Engine: D&D
I would suggest a sheet metal supplier and ask for dust collector hose
Cheers Greg
11-03-2008, 07:37 AM
Cobra Make, Engine: 2 AC Aces, 1 w/289, 1 w/TBD
Not sure what length you need, but Moss Motors carries 4" heater hoses. They have various sizes, but a couple of their part numbers for checking are 456-120 (31" in length) and 456-130 which I do not have a length for.
Jay
11-03-2008, 09:28 AM
AZ.
The vinyl hose for your cloths dryer ex./vent hose works and last pretty well. It is available at any place like Home Depot etc., the aluminum hose does not work as well because it is much stiffer and does not take corners as well.
11-03-2008, 12:22 PM
Cobra Make, Engine: KMP478
I used SCEET hose from Aircraft Spruce. It is a bit pricey, but I wanted something to stand up to high temperature as it is fairly close to the exhaust headers.
http://www.aircraftspruce.com/catalog/appages/sceet.php
Jason
11-03-2008, 03:47 PM
Ca.
You might be able to get it from McMaster-Carr. http://www.mcmaster.com/
Terry
11-03-2008, 04:13 PM
On McMaster put in part # 5222K23
11-03-2008, 04:44 PM
Cobra Make, Engine: BDR#078,408 Dart Block, TKO 600,Indigo Blue, White Stripe
I use hose from Walmart. They sell it in the RV area. It is used to empty the
holding tank on RV's. I used it on my FFR for vents leading from the brake ducts opening to the foot box.
I have since used the same hose on my BDR and corvette for brake cooling ducts. The cheapest answer to your question. It's worth a try and will work.
JayB
Jupiter, FL
11-03-2008, 08:12 PM
AL
Lowes 4" aluminum dryer vent hose.
Dwight
11-03-2008, 08:24 PM
AL
fans on ebay
11-07-2008, 01:31 PM
Thank you all for the advise and info. I will try the drier hose first.
Rob
11-07-2008, 04:58 PM
02 Super Duty 7.3L
11-07-2008, 06:16 PM
This is the way you want to go if...
you want to do it right.
Hosenow 800-467-3669
silfab 2 FLX2005 3.25 ID
Morgan LeBlanc
Fresno CA
11-09-2008, 03:01 PM
Aluminum dryer hose looks cheap!!
JayB
Jupiter, FL
