Keeping It Cool
http://www.clubcobra.com/forums/all-cobra-talk/92932-keeping-cool.html)
| ROBERT GWALTNEY |
11-09-2008 07:43 PM |
Keeping It Cool
I'm at the point where I,m ready to put the body on. I would like to know what type of heat shields work best. I thought I would cover both interior and exterior sides of the trans tunnel and foot boxes. And do the self adhesive type hold up on the underside of the body.
thanks Robert
| sparks |
11-09-2008 07:57 PM |
I wouldnt think that putting it on the inside wouldnt do much good.....Most of the deflection would be done out side...Maybe a double layer on the outside w/ maybe a 1/4 in. gap between for air circ..????????just a thought . I would not use tape to mount!!!!!
| 427 S/O |
11-10-2008 04:57 AM |
The aluminum bubble insulation works great, just put in under the carpet and inside firewall. I would keep the underside clean as possible..imo.
| Ron61 |
11-10-2008 05:15 AM |
I used ThermoTech on mine and it helped a lot. Easy to work with and you can glue it on or use rivets. I believe what I used was rated to withstand 2,000 degrees. I covered the firewall, all brake lines, and also the underside of the transmission tunnel.
| All times are GMT -7. The time now is 02:37 PM. |
