Old 01-28-2009, 07:36 AM
coinop101's Avatar
Cobra Make, Engine: 1985 Cobra 427
Default Scca Track Events
Hay
Anyone out there run Scca track events with their Cobra cars ? If so , what class and at what track ( north east ) . I think it's a solo II street classification .
Thanks for all past responds to my questions , they been very helpfull
Peter
Old 01-28-2009, 10:23 AM
Cobra Make, Engine: CSX4000 w/CSXblock
Don't believe most Cobra's will pass tech inspection.
Old 01-28-2009, 03:04 PM
Default SCCA regs
You are actually asking two questions. I believe that you are interested in open-track road courses and/or local autocross events (Solo2).
As far as SCCA classes, it would be very difficult to get your car to pass tech in the generic "run anything" ITB class. Raise the roll bar, update the belts and fuel cell, install Lexan, mount fuel inspection port in the fuel line, and more; get Nomex undies, SP 5-3 or better driving suit, and some arm restraints for the cam-lock; then, take a school and run a Regional or Double National event would be the start.
NASA's time trials sound cool and you "run whatcha brung". Check your region's website to determine qualifications. Take the penalties for weight and C.I. displacement, and just go have fun.
SCCA's Solo2 is commonplace in most cities. Your replica would fit easily in the AP class (if your group deleted that class last year, then you will run XP). If entries are low, then they bump you into the nearest class that can field cars. AP bumps to BP bumps to CP bumps to DP... basically including heavier and heavier cars as the class shifts.
Here's the real kicker: Solo1. Same classes, same simple tech rules ("secure everything and snap on an extra throttle spring"), but the speeds go from 40 mph maximum with the course run entirely in 2nd gear (Solo2) to 75 or 80 mph max with the driver sawing the wheel and running through the gears. Tho Solo1 eats up tires and brakes in a few runs, I think it is absolutely a blast. Ask around regarding the high-speed Solo events. People will tell you which events to sign up for. There is always a pro that conducts a novice walk-thru early in the AM, so don't let the course intimidate you. Have fun and remember that you will need to work out on the course for one of the Heats (or volunteer in Tech and your work assignment is out of the way before the driver's meeting--cool!)
Wish you the best,
Paul
SCCA TX Region
Note: In this event I ran AP against two Superformance 427s. I got the trophy at the end of the day, but they had more fun! I normally run BP (a vintage Vette and Cobra 427s when AP gets bumped up). Cobras with heat-cycled sticky-compound tires are VERY VERY competitive in autocrosses.
Old 01-28-2009, 03:41 PM
xracerbob's Avatar
Since you are in the northeast, you might want to check into these guys-
http://www.scda1.com/home
I'm hoping to run with them some this summer. The July Watkins Glen date should be a mandatory Cobra event!
Old 01-28-2009, 04:00 PM
lovehamr's Avatar
Stolen Avitar
Paul I feel for you running your Shelby against real 2 seaters. I ran my Boss 302 in San Antonio solo 1s quite a few times and it seemed like the course was always set up by some goober with an MG. Sometimes my car wouldn't hardly fit through some of the gates!
Steve
Old 01-30-2009, 07:10 PM
Default Tires helped
I found stickier tires and steering box tightness brought me up past the over-powered Superformance Cobras. And yes, goobers in MGs are always put in charge of course design.
Best,
Paul
Old 01-30-2009, 08:31 PM
WildBill3's Avatar
If you like a more open course run solo1,that will get some pucker going.
I agree Life is way to short to worry about gas milage.Other rides Crewcab Super Duty F350 Ford,Shlby Charger,66Mustang/Frankinstang,Chevy Van,KTM Dualsport,FFR Daytona Coupe SOLD... RUN N GUN 06,07,08,09 Hallet 09,
