November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 04-18-2009, 11:22 PM
Cobra Make, Engine: ERA 289 FIA #2027, 65' 289" PS wheels
Default may want to do a thermostat
SSnake,
Many of us have the problem of low oil temperature, big or small block, even with the oil cooler blanked off to stop airflow.
I just ordered the Canton thermostat from Summit for $145. It comes set up for #12 lines which should work for your setup. Visually it appears to have more flow capacity than the MOCAL unit or the EARLS which are both set up for #10 fittings.
(that said I have not seen ANY measurements on flow rates for any of them).
I decided on the Canton as it is set to open at ~215. The MOCAL and EARLS are set at ~180. The MOCAL can be ordered to open at ~215 but then it is approaching the price of the CANTON.
My engine, stroked 289 runs cool, on the street oil is 150/160 stuck in traffic and drops as soon as the car has >airflow or >engine speed. Oil very rarely exceeds ~200 even at the track so I opted to go with the 215 setting.
MOCAL says their unit starts to open at 160 so I don't think it would do much for me.
The BEAUMONT unit is beautiful, very simple but at $330 too pricey for me. I still like the thermostat concept as my oil temp drops as soon as I am on a straight away or going down hill, I want the temp to stay up...but I have lots of reserve so getting heat soaked shouldn't be an issue.
I think all the thermostats will still allow about 10% of the oil to flow through them so the temp in the cooler isn't totally cold.
One downside to the CANTON is its size...6 inches high and 3.25 square...the MOCAL unit, and the EARLS are more compact.
Dean, aka ""RED-BARCHETTA" has a CANTON unit on his 351/390 stroker, maybe he or some of the other guys will comment.
ERA 289 #2027
Old 04-19-2009, 11:51 AM
Banned
Dean, aka ""RED-BARCHETTA" has a CANTON unit on his 351/392 stroker, maybe he or some of the other guys will comment.
Mine is mounted similarly to Jim's. We both fashioned a plate to mount ours on. He mounts his closer to the fans and mine is more offset toward the motor. Niether one of us centered it on the cross-member, as you will discover with the mounting bracket that this makes it difficult to do so. This isn't the best pic (Jim's is more of a close-up), but at least you get a feel for how it looks in the whole engine bay. I still haven't come up with a cleaner way to route the plumbing from the remote oil filter exit back to the intake on the thermostat. Have considered some hard line but the bends would be too tight. Maybe Jim can share with us an underneath shot...his looks cleaner.
Overall I'm pleased with this unit.
-Dean
Old 04-19-2009, 12:48 PM
Blas's Avatar
Cobra Make, Engine: SPF#0760
IF you want a bypass valve that is manually controlled, check this site out. He make some great stuff...
www.beaumontmetalworks.com/index-perf-ap.html
SPFWiringDiagrams@Comcast.net
Old 04-20-2009, 08:08 AM
DougD's Avatar
Cobra Make, Engine: Sold my beloved Shelby CSX 4068, Gessford 427 Ford
I investigated installing a Mocal but decided against it. They come in -10 and -12 sizes and are fairly small compared to the other brands I've seen. Even so, I couldn't come up with a way to mount it that I could live with.
The directions that come with the Mocal indicate that it never really closes completely like you would think - it uses the viscosity differences between warm and cold oil to redirect the oil back to the engine. As the oil in the line to the cooler slowly warms, more of it begins to flow through the cooler.
Pegasus has them for $110 if anyone is interested.
I've decided to warm the engine fully before driving any distance, and use some good ol' duct tape on the cooler if I decide to drive in cooler weather. I'm pretty sure the 427 will run warm regardless of the outside temp as long as it's not COLD out.
CSX4068, '69 Bronco, '70 BOSS 302, '87 Mustang GT, '08 Roush Trak Pak
Old 04-20-2009, 04:23 PM
twobjshelbys's Avatar
-Dean
I think I need one of these as my oil temp rarely gets off the bottom peg and when it does only goes up to about 60*C. Water temp is about 80-85*C. However, I'll also need to find the braided hoses in the right lengths. What lengths/sources did you use?
Old 04-20-2009, 04:39 PM
Maybe this is a silly question - but doesn't the reading of the oil temperature depend on where the sensor is located? Mine is located in the pan [I think) so wouldn't the actual temperature of the oil that is circulating in the engine at that moment differ quite a bit? How much of a difference could I expect?
Also - I have a 7 quart pan.
Old 04-20-2009, 06:40 PM
Banned
Just go to Summit Racing (or Jegs) and buy the 6ft pre-cut lengths. Then measure three times and cut once. Use a rubber hose (any diameter) for mocking it up. I inherited -10AN and at one point almost jumped to -12AN. -12 is a LOT larger. I also used all Aeroquip fittings...they cost a little more but I wanted the best.
-Dean
Display Modes
