Forgetfull ol' farts and toggle switches
I ran across these and couldn't resist ordering a set. Every year, in the spring, there's at least 1 or 2 toggle switches that I can't remember what they did/do..
www.augerresources.com/switchlabels.htm
| madmaxx |
04-27-2009 11:39 AM |
Not a bad idea after i had just waxed my car and hit the windsheild washer toggle instead of the headlight.
| vector1 |
04-27-2009 12:03 PM |
hope your ciphering brain cells don't take a vacation. i went the old label maker route and used plain english.
good idea though and looks good.
| sllib |
04-27-2009 03:59 PM |
I was gonna use clear P-touch labels with white lettering but these look pretty good. Thanks.
Bill Stradtner
| patrickt |
04-27-2009 04:34 PM |
C'mon!
Jeez guys, it's only three, or four at the most, switches. If you can't remember them then that's pretty sad....:LOL:
| RodKnock |
04-27-2009 04:41 PM |
Originally Posted by patrickt
(Post 943762)
+1. Also on my car the fuel switch is under the fuel pressure gauge and the fan is under the temp gauge. And if you don't drive at night or through any moisture, then who cares about the light switch and wipers. :LOL:
(Post 943762)
Patience grasshopper, your time approaches ..:LOL:
| 55312 |
04-27-2009 08:54 PM |
LOL :LOL:
How often do you use your wipers? Your heater? I haven't hit the right switch when I've needed one of those in 5 years!
Tim
| twobjshelbys |
04-27-2009 10:11 PM |
I reached for the lights and loved it when I hit the fuel pump switch...
| rodneym |
04-27-2009 10:47 PM |
Am I the only one who carries a copy of my dash switches xeroxed from the owner's manual?
| FUNFER2 |
04-28-2009 12:47 AM |
I like the air compressor ! lol
| Ron61 |
04-28-2009 07:08 AM |
Those are nice. My worst problem was remembering which was the fuel pump switch and the car would run about 1/2 block with the pump off before stopping. It is embarrassing to be sitting there trying to get it to start and having people stop and tell you what a great ride you have. I finally marked mine with a very small tab that had ON on one end and OFF on the other.
Ron :p :o
| Randy Rosenberg |
04-28-2009 11:20 AM |
I kinda like the idea of my dash switches be unlabeled - it adds a tiny bit of security: if some would-be theif got her started but couldn't get far due to not knowing which switch was the fuel pump (assuming I had an electric fuel pump on a dash switch).
| patrickt |
04-28-2009 11:22 AM |
Originally Posted by Randy Rosenberg
(Post 944081)
For those of us with mechanical fuel pumps, we could just label a dashboard switch as "Fuel Pump" and have it ground out the ignition when switched "On.":3DSMILE:
| Ronbo |
04-28-2009 01:31 PM |
Just get a tatoo on the inside of your right wrist with the pattern...
The chicks will dig it.;)
| Sharroll Celby |
04-28-2009 04:13 PM |
Back in the 60's, the switches were probably labelled with one of those "DYMO" embossed tape machines, where you turned the wheel to imprint the label.
I still have mine from when I was a kid. I even have some of the tapes as well!
| All times are GMT -7. The time now is 07:31 AM. |
