November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 05-23-2009, 07:08 AM
Originally Posted by turnpike boy View Post
Why on earth would you be looking to use 50wt in the car?
Is the motor so worn out that it can't hold pressure with 10wt? Or put together with clearances so big that it can't hold pressure? Is it a blower motor, intentionally put together with lots of clearance?
Apart from reasons like these, there's just no way you should be looking to run such a heavy oil.
X2! You will lose HP and anything less than a 70 degree day in NY state where you live, it's like dragging the rings through glue. On cold startup you risk blowing the filter off (depending on brand and pressure).
Call Eric at PE who built your engine for his advice. Don't think he'd approve. I doubt that you're endurance racing or at the 3HP/cubic inch level.
If you persist with this bad idea, you'd better have a HD oil pump drive shaft.
Chas.
