| tortuga |
09-04-2015 06:44 PM |
LeMans Bowls on H 850?
Is this a straight forward bolt on modification or is there more to it than swapping bowls and fuel lines?
Thanks
| 4pipes |
09-04-2015 08:06 PM |
I had LeMans bowls 10 years ago, while I don't remember the details (old fart), I DO remember the needle valve stuck open and pumped gas our the vent tube onto a hot manifold. There's something about the needle valve configuration that can lead to this problem.
| mickmate |
09-04-2015 08:12 PM |
The Le Mans float bowls go right on your Holleys. They can be touchy on float levels and need to be set off the carb. Make sure you have a front and a rear. On Cobra applications they didn't use the float bowl crossover tube as we have fuel logs.
| tortuga |
09-05-2015 08:24 PM |
Mick are you saying that i would use my existing log? All the old photos of the setup looked to be setup with a series of hoses?
I ask the question as I have experienced no then too much throttle during spirited backroad hijinks...The idea of getting 450+ HP suddenly to the rears when throttle is over applied on lack of response is a bit concerning...Or losing it due to trailing throttle oversteer at the wrong time...
Thanks
| All times are GMT -7. The time now is 03:06 PM. |
