-   Antique & Collectibles (http://www.clubcobra.com/forums/antique-collectibles/)
-   -   Roll Bar Bezels for Ant & Collectible (http://www.clubcobra.com/forums/antique-collectibles/65430-roll-bar-bezels-ant-collectible.html)
jerry w 06-16-2005 02:40 PM
Hey Guys,
Where can I find bezels for the roll bar I got from Antique and Collectible? Tried Finish Line, but their set comes with one oval for the rear upright. I have Three 2 inch round uprights:confused:
Appreciate the time to all who respond.
Jer
PNJSNAK 06-16-2005 05:53 PM
Jerry: your roll bar should be 1 3/4" in dia. Finish line sells 1 1/2" and 2" dia bezel kits. Yes thiers is oval for the rear down support bar. The 1 1/2" is to small and the 2" is too big.
Here's what you can do. You can use the 2" from finishline and fill in the gaps around the rubber grommets (Like what I did) or you can get the 1 1/2" size from finish line and very carefully use a 1 3/4" dia hole saw and carefully bore out the rubber grommets. I am told one can do this but be careful and slow when you are boring the grommet, of course I was told after I installed the 2" ones. OR you can simple use the grommets that come from A & C with out bezels like I did for three years.
Good Luck.
Jim
jerry w 06-16-2005 05:58 PM
Thanks for the reply Jim,
Seems I may have to fabricat/adjust something myself. I think I will start with a grommet.
Jer:)
gman 04-18-2006 06:33 PM
Rubber Grommets
Found these for that odd 1 3/4" roll bar on your A&C.Picture in my Gallery. $5.00 each. What do you think? Gman
slithering 04-18-2006 06:48 PM
Jerry,
I made my own bezels with a product called Devcon Flexane 80. This is a two part pourable rubber you can mold to any shape. They also carry flex additives and release agents. I cast a mold out of plaster of paris. Great product!
Chris
jerry w 04-24-2006 03:26 PM
Thanks for the reply Guys! I ended up making these out of aluminum.
Jer
[IMG]http://www.clubcobra.com/photopost/d...cobra_roll.JPG[/IMG]
Three Peaks 04-24-2006 03:35 PM
g-man, sent you and email on your source for the rubber grommets.
Bob
EarlsflyinCobra 04-24-2006 05:09 PM
g-man, ditto on the email for your source.
Earl
gman 04-24-2006 06:43 PM
Grommets
OK Guys, I was going to get rich on these grommets since 1 3/4" are so hard to find, but I'll let the cat out of the bag. Check my gallery. You,ll get a good laugh. :LOL: The top half is rubber and the bottom is plastic but they separate at just the right part. Very pliable and water tight. Haven't decided if I want bezels or not. These look good with some AmorAll.
Gman
EarlsflyinCobra 04-24-2006 07:10 PM
Thats toooooooooooooooooooo funny...........................
Three Peaks 04-24-2006 08:23 PM
Now, why didn't I think of that? I use roof jacks all the time! LOL - I needed a good laugh today, Thanks,
Bob
gman 04-24-2006 08:42 PM
For you guys that like a single 3" ,they can acomodate too. Gman
