Clutch
http://www.clubcobra.com/forums/antique-collectibles/70907-clutch.html)
| Coobra |
07-04-2006 06:16 PM |
Clutch PLEASE!!!!!!!!
Almost finished. Just have to complete the clutch installation. I bought everything Joe T. said in the manual but I am having an issue with the set up. Even a picture of the slave set up would help.............
It's a T5. Anyone use anything different as far as a clutch is concerned? :CRY:
| Coobra |
07-11-2006 08:26 AM |
Really need some help here guys...............Please
| bamcoc5 |
07-11-2006 09:10 AM |
Try this site. Fortes is very good with products and questions on T5 trans & slave units. I would give them a call. They are a supporting vendor on the Factory 5 site.
http://www.fortesparts.com/
| Haz331 |
07-11-2006 01:40 PM |
You also might want to look at autoworksracing.com. I used their set-up and I'm completely satisfied. Little pricey $$$ but a nice product.
| Roscoe |
07-12-2006 06:56 AM |
I've got a Tremec 3550, basically a T-5. I'm using a Tilton hydraulic throw out bearing on a Centerforce Dual Friction clutch. This setup has over 25k miles on it. A recent engine rebuild revealed that the clutch plate had little or no wear on it.
I went with the hydraulic bearing because of the ease of setup. Couldn't be happier.
I also have a Tilton floor mounted pedal set.
| Coobra |
07-13-2006 04:43 PM |
Thank you for the assistance. Problem solved. I really appreciate it.
| All times are GMT -7. The time now is 02:56 AM. |
