Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Antique & Collectibles
December 2025
  #21 (permalink)
Old 08-07-2007, 08:09 PM
Naumoff's Avatar
Cobra Make, Engine: Unique 427 S/C 427 FE S.O. 484 cu in
Tech Line: 270-781-9741
Call them and see if this will work.
REPLACEMENT FUEL BOWL KITS Part #
Standard 134-101
Shiny 134-101S
Replacement primary fuel bowl.
Side-hung-float style with provision
for transfer tube and accelerator pump.
Used on model 4160 carburetors.
http://www.holley.com/BrowseCatalogs...olley&Page=101
  #22 (permalink)
Old 08-08-2007, 12:49 PM
I ordered my new bowls from Summit Racing today. I put a rush on them so they should be here early next week. i will be very carefull this time when tightening them up.
Thanks for everyone help
automan
  #23 (permalink)
Old 08-16-2007, 08:24 PM
Hey Guys, should the accelorator pump spring be applying pressure on the lever underneith the bowl or just sitting on it. I installed my new bowls but now cant get the car to start. I'm flooding the hell out of it. I filled up the bowls with gas. Removed all the spark plugs and most were wet. They were also black (running rich, i knew that). Anyway, both levers have pressure on them from the spring. should i adjust it so that it is only touch and when the accelorator calls for it, then it applies pressure.
Let me know
Thanks
Automan
Rate This Thread:
