-   Antique & Collectibles (http://www.clubcobra.com/forums/antique-collectibles/)
-   -   cluch slave (http://www.clubcobra.com/forums/antique-collectibles/92591-cluch-slave.html)
saltshaker 10-25-2008 05:01 AM
cluch slave
anyone have pictures of the bracket they made for the nissan cluch slave on a FE motor..did anyone use a different setup and a different master cylinder then the Honda Accord?
Thanks, Jon
convincor 10-25-2008 02:07 PM
I borrowed the slave idea from a Unique in my FFR
Uses a 1960 Ford P/U slave (NAPA# 33721)
Using a Wilwood triple master.
http://i101.photobucket.com/albums/m...e/IM001326.jpg
FinishLine sells a kit that uses the same slave-
http://i101.photobucket.com/albums/m...kage/slave.jpg
Blittleton 10-25-2008 02:26 PM
I have designed this setup for my Backdraft's, SPF's, should work with just about any cobra using a quick time bellhousing or Stock aluminum housing from Ford. Using a Lakewood or Mcloed bellhousing need just a minor grind out of the opening for clearance. Give me a call if you are interested in this setup. 859-630-9099
http://www.clubcobra.com/photopost/d.../DSC_00083.jpg
http://www.clubcobra.com/photopost/d.../DSC_00132.jpg
http://www.clubcobra.com/photopost/d.../DSC_00123.jpg
http://www.clubcobra.com/photopost/d.../DSC_00102.jpg
saltshaker 10-25-2008 02:47 PM
cluch slave
thanks for the pictures...my trans is a toploader and the slave recomended is fron a nisan truck which if i'm right is a push slave...the shaft on the slave isn't threaded on the end. would someone were to have a picture suing that slave??
convincor 10-25-2008 03:04 PM
not knowing what year Nissan I guest at 1996.
2wd
4wd
saltshaker 10-25-2008 03:21 PM
cluch slave
the slave looks simular..2 wd ..1987-92 truck
convincor 10-25-2008 03:30 PM
Pic
1990, D-21, V-6
