Old 01-11-2022, 07:22 PM
NoVA Cobra's Avatar
Cobra Make, Engine: SPF1439 427FE s.o.
Default NoVa Cobra clutch
Soooo...my clutch finally gave out this weekend. It's been going bad for some time, but it grenaded fairly quickly to full stop on a 20mi drive Sat AM - had to flatbed it back to home base. Just got it all apart - and clutch looks fairly good - as does the flywheel. It's the throw-out bearing that collapsed. Though the fingers are shot so I'll need a new clutch anyway. And since it's apart, I want to get a rebuild on the tranny and resurface the flywheel. So who here likes to do their own work - and can recommend any locals to do the rebuild and resurfacing? It's a 2003 TR3550-TKO. Thanks!
Superformance 1439 w/427FE side-oiler. 2007 GT500 40th Anniversary CSM07XL0078. 2007 GT500 40th Anniversary CSM07XL0085.
Old 01-11-2022, 10:20 PM
Hi John, I've had B&B Machine do a few flywheels for me and have been very satisfied with their quality of work, quick turn around and price. They are on Broadway in Mesa. When my initial throw out bearing bit the dust, I replaced it with one that has a grease fitting so it can get the occasional shot of grease. I did have to drill a 1" hole in the scatter shield to be able to get to the fitting. I use an expandable rubber freeze plug to keep crap away from the clutch. Just my 2¢.
Old 01-11-2022, 11:34 PM
Had https://dnmauto.com/ install new clutch https://www.mcleodracing.com/rst/p31 in both hot rods, 650 & 700hp. Kit includes flywheel plus 1 needed throw out bearing.
Good job, on time. Feels great. Not cheap.
SPF has TKO 500 GT500 has T6060.
AZ Bob
Old 01-12-2022, 09:56 AM
"Not Cheap" is an understatement.
Old 01-12-2022, 10:10 AM
Danr55's Avatar
PRK Auto in Mesa did the work on my car when the transmission blew up. They do really good work are on time and Randi is always ready to pass along information and answer questions.
Dan in Arizona
CCX3209
Old 01-15-2022, 10:28 AM
John, do you have the car running again? Looks like you had to pull the transmission up through the tunnel. That's the way I did mine and I thought it actually made it pretty slick.
R U ready for a run?
Old 01-15-2022, 07:59 PM
NoVA Cobra's Avatar
Yep - I don't know why there's always a debate about either pulling tranny thru interior, or dropping after cutting x-member. It's not difficult at all to take out the seats and tunnel - a couple hours and the tranny was out. Cutting the x-member is highly discouraged by SPF... https://superformance.org/scof_tech_...terations.html
Not ready yet - still a work in progress. Waiting on new pressure plate, disc and pilot bushing. I have new TO bearing and installed new pedal that I broke trying to work the clutch when the TO failed. I punted on resurfacing the flywheel and rebuilding the tranny in the interest of time. And neither were bad anyway. I should get it all back together by next weekend. Tho I also want to replace my tie rod ends and ball joints after that. Front end needs some tightening up.
Old 01-16-2022, 08:02 AM
First, my clutch, flywheel, etc was all changed under the car, second for John, Performance Unlimited, Cobra Valley has ALL upgrade parts you need. Cobra Valley Parts & Accessories for Ford 427 Shelby Cobra, AC Cobra, Superformance, FFR, ERA, Unique, Contemporary and more Such as: Cobra Valley's R/T Super High Performance Ball Joints. Have not needed ball joints or sway bar ungrade kit but I'm told they are GREAT and will use in the future if needed.
AZ Bob
Old 01-16-2022, 09:54 AM
John, there's a really good alignment shop on East McDowell (I think) in Phoenix that has done a lot of Cobras. They know what and how without needing to punch the car into a computer. I'm sure someone will come up with the name. I haven't needed them in many years, and I've slept since then.
Old 01-16-2022, 10:08 AM
Network Alignment & Brakes I've been to only the Cave Creek Shop with the Cobra.
AZ Bob
Old 01-16-2022, 02:27 PM
ah ha! Found it
Jack's Alignment
2902 East Thomas
Old 01-23-2022, 07:57 PM
NoVA Cobra's Avatar
So the bell was a mess - totally caked and baked on crap. Cleaned it up and painted black. New disc and pressure plate installed. Tranny and driveshaft back in. Also replaced all sway bar bushings since it was up. Replace tunnel and seats tomorrow. Hope to get new ball joints and tie rod bushings in next.
Old 01-23-2022, 08:00 PM
NoVA Cobra's Avatar
Good time to clean out interior. Quaint to think bell was painted black before...
Old 01-23-2022, 08:38 PM
It's all so disgustingly clean!
What type of T/O bearing did you use?
Old 01-24-2022, 06:18 AM
NoVA Cobra's Avatar
Permanently sealed. Don't want a repeat. https://www.summitracing.com/parts/ram-485
Old 01-24-2022, 09:03 AM
You know a lot of us remove the little weights on CF pressure plates. It tend to hamper high speed shifts more than it helps.
Old 01-24-2022, 06:38 PM
NoVA Cobra's Avatar
Success. All back together and like new again. I sorely needed this fixed. That bearing had been going bad for some time. I couldn't tell that was the issue. Glad that's done with. Ball joints and tie rod ends next.
Old 01-24-2022, 06:39 PM
NoVA Cobra's Avatar
So now you tell me.
Old 01-24-2022, 06:44 PM
Originally Posted by NoVA Cobra View Post
So now you tell me.
Yes, I'm sorry about that. Here is the write up from Chuck Brandt on his experience with the weights. https://www.chuckbrandt.com/living.htm I remember talking with him about it (almost 17 years ago). Scoot down to his September 16th, 2005 entry and you can read about it. Sorry I didn't flag it sooner but at least you know what to look for.
Old 01-24-2022, 06:53 PM
NoVA Cobra's Avatar
AZ Bob
Actually got the sway bar and end link bushings from them. Didn't get the upgraded ball joints - maybe next time. Just got SPF replacement parts.
