6Likes
12-19-2010, 03:37 AM
Sevenohms, sh!t, I thought our Classic Revival chassis had a lot steel to them, that chassis is built like a tank! Keep the pictures coming.
Regards.
Mando
12-19-2010, 03:32 PM
VIC
Cobra Make, Engine: Venom, BF XR8 260kw, 6 speed auto
More Photos
12-19-2010, 04:33 PM
NT
Lookin good Nathan, keep up the good work and progress pics/updates.
Cruising in 5th
12-20-2010, 04:23 AM
qld
sevenohms looking good , hope to see more on the build
send photos of mine when it arrives
rob
04-07-2011, 12:26 AM
VIC
Update 7/4/11
Update:
Finally got round to progressing a bit on the cobra.
Made the trans mount, after getting the sign off the engineer
Made the engine mounts, which I have to redo.
So engine is in position so driveshaft etc can be made
Front end minus shockers is in
Wheels are due on the weekend, that I can use to roll around
Finished the calcs for the brake system, awaiting signoff from Engineer
Looking at Floor mount wilwood pedal with dual 3/4" MC and Wilwood 1.75 four pots on the front, standard jag rear.
Still trimming loom down, extracting old Ford systems from the loom.
04-07-2011, 12:29 AM
VIC
4078: Front End
4079: Overview
4075: Transmount. Needs radiusing after the final welds and gussetting
04-07-2011, 05:54 AM
NSW
Originally Posted by sevenohms
Update:
When I built mine the engineer insisted I use all the same brake components on the rolling gear and similar sized stuff on the actuating gear. I used Jag callipers and Ford actuators ( the ford bits were the same dimensions ) The RTA still requested a major brake test AND all dimensions of the components of ALL the brake bits. I passed ...eventually. I have heard that Willwood brakes aren't smiled upon by the 'authorities'. Check this out before you go any further. Willwoods don't have weather seals. good luck !
04-07-2011, 07:02 AM
NT
I have heard that Wilwood now do do a caliper with seals.
And seven, thanks for the update, keep them coming.
Cruising in 5th
04-07-2011, 03:56 PM
http://wilwood.com/Calipers/CaliperL...ro%20Dust-Boot
Even though the ad says "No" when referring to dust boots, this model does in fact come with them.
Don.
04-07-2011, 04:00 PM
NSW
Yes, dust seals requirement was added to the new VSB14 in January this year.
04-27-2011, 06:38 PM
VIC
Emperor has boots! Now its time to clean the shed, and find all the tools and things lost under the chassis!
04-27-2011, 06:40 PM
VIC
Originally Posted by Merv and Sharon
Many would say no upper level is too much. However, that much power would need the right gearbox, diff and brakes. I find that the limitation is often the suspension and how well set up it is for driveability. I am not sure how strong the bottom end is on that motor. Others would know more.
I spoke to a tuner in Sydney reckons he can get 600kw from a twin turbo version, I think thats the upper limit! HAHA
04-27-2011, 08:13 PM
NT
Looking good, but yep, time to get the broom out.
Cruising in 5th
07-09-2011, 08:20 PM
any more updates?
07-11-2011, 04:26 AM
NT
Of Topic......
Cruising in 5th
Reason: Deleted at request of OP
07-12-2011, 05:21 PM
VIC
Originally Posted by wrxbouy
any more updates?
I've made some progress, but I have annual leave coming up and hope to push on with more work, so I'll update then!
07-12-2011, 06:32 PM
NSW
Nothin to see, move along here!
07-12-2011, 07:32 PM
NT
Off topic.....
But I still think the seller of this kit is an idiot who should be run out of business.
Cruising in 5th
07-12-2011, 07:46 PM
VIC
Sorry, off-topic
07-12-2011, 08:06 PM
Vic
_____________________
Reason: DELETED!!
