November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
  #21 (permalink)
Old 02-18-2011, 10:31 PM
Modena's Avatar
no doubt they will tune it down to be 10kw more than the Ford
Ben in AU
  #22 (permalink)
Old 02-18-2011, 11:12 PM
Merv and Sharon's Avatar
Great for a Corvette. Looking forward to the Ford Coyote and Cobra coming together here. Almost wish I was starting again ...
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
  #23 (permalink)
Old 02-19-2011, 12:04 AM
Donunder's Avatar
Don't wish it Merv ---DO IT!
Queensland leads the way again...
Out of the muddy floods and that crazy Yasi, into the golden light, comes Merv's blown Coyote Cobra, silver grey with black mirrors, black wheel centres, black roll bar and pipes...
You know you want to. We're only here once. Can't take it with you... All that stuff. Go local or go SPF. Whoa, I'm excited!
Don.
  #24 (permalink)
Old 02-19-2011, 01:11 AM
Geez, Don calm down there! Feels like I just 'finished' this one! However, if my motor every karks it ...
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
  #25 (permalink)
Old 03-15-2011, 06:04 PM
Originally Posted by sambo View Post
Looks like GM/Holden may have an answer.
http://theage.drive.com.au/motor-new...218-1ayxg.html
"The new engine tipped to be fitted to HSV's new range by 2013 is expected to be based on the engine in the wild Chevrolet Camaro ZL1 that was unveiled at the Chicago motor show.
With 410kW of power the new supercharged 6.2-litre V8 delivers 26 per cent more power (85kW) than HSV's most powerful cars on sale, the GTS and Grange, and almost 10 per cent more than the most powerful Australian-made car ever, HSV's limited edition W427."
That's the LSA out of the Cadillac, I'm guessing it's been tweaked for the Camaro ZL1.
  #26 (permalink)
Old 03-15-2011, 06:12 PM
Jake's Avatar
Cobra Make, Engine: Superformance Cobra #1628, Coast Performance Stroker 427W Ford 520HP/535FT.TQ, Blue with white stripes
The idle leaves a little to be desired. But I love everything else that it brings to the table!
Jake
If your going to dream, dream big!
  #27 (permalink)
Old 03-15-2011, 06:58 PM
CobraEd's Avatar
Jake
The idle leaves A LOT to be desired.
LIFE IS TOO SHORT TO WORRY ABOUT GOOD GAS MILEAGE
________
Utinam logica falsa tuam philosophiam totam suffodiant!
________
  #28 (permalink)
Old 03-15-2011, 11:50 PM
Cobra Make, Engine: Harrison build #98 with Supercharged 6.2L of Chev Power, TKO600 5 speed gearbox
This will be the type of setup I will have on my car. LS3 with a 1900cc supercharger on the top, water to air intercooler. Initial runs with a pea shooter tailpipe have >300Kw at the wheels on base tune, move to a more open exhaust and should have >350Kw at the wheels and a great induction sound.
  #29 (permalink)
Old 03-16-2011, 03:50 AM
That begs the question....what are you doing idling anyway !!
Rog 246
Harrison #100
  #30 (permalink)
Old 03-16-2011, 06:44 PM
Kanga's Avatar
LS LS LS, Wouldnt change from an LS. Cheap, great power great choice. LS1, 2 3, Ls 7. From 5.7 litre to 7.0 litre why would you bother with anything else, light weight and it fits. The old ford holden argument is a thing of the past at least here in Australia. The fun police have taken our choice.
steve
  #31 (permalink)
Old 03-16-2011, 08:51 PM
Steve,
Do you still have the Holden stroker in yours?
Ben
  #32 (permalink)
Old 03-16-2011, 10:56 PM
Kanga's Avatar
No Beejay I have gone to an LS1 with the t56. I loved the old holden but tuning and power was nowhere near the LS. So many more options, Im thinking of going to a strong 6.0 litre or stroke the 5.7 we will see what winter brings!!
  #33 (permalink)
Old 03-16-2011, 10:58 PM
AC-460's Avatar
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
This is a Modular engine...check out the spec's
5.0 L CoyoteThe 5.0 L (4951 cc, 302 cid)[9] "Coyote" V8 is the latest evolution of the Modular engine.[10] It shares the 4.6 L's 100 mm (3.937 in) bore spacing and 227 mm (8.937 in) deck height,[11] while bore diameter and stroke have increased to 92.2mm (3.63 in) and 92.7mm (3.65 in), respectively. The engine also retains the 4.6 L's 150.7 mm (5.933 in) connecting rod length, which produces a 1.62:1 rod to stroke ratio.[12] The firing order has been changed from that shared by all previous Modular V8s (1-3-7-2-6-5-4-8) to that of the Ford Flathead V8 (1-5-4-8-6-3-7-2).[12] Compression ratio is 11.0:1, despite having typical port fuel injection (as opposed to direct injection) the engine can still be run on 87 octane gasoline.
The Coyote features a revised aluminum engine block with improved strength and crank-case ventilation, and all new 4V DOHC cylinder heads that have shifted the camshafts outboard, which allowed for a compact roller finger follower setup and improved intake port geometry. The result is an intake port that outflows the Ford GT intake port by 4 percent and the Yates D3 (NASCAR) intake port up to 0.472" (12 mm) lift, which is the maximum lift of the Coyote's intake cams.[12] The Boss 302 features versions of these cylinder heads with CNC ported intake/exhaust ports and combustion chambers, along with lightened valve-train components and lightweight sodium filled exhaust valves. The Coyote also features a forged crankshaft, powdered metal rods and hypereutectic pistons with oil jets to help piston cooling, while the Boss receives forged connecting rods and pistons.[13] Engine redline is 7000 rpm for the GT and 7500 rpm (est) for the Boss 302.
The engine is Ford's first V8 application of cam torque actuated (CTA) Twin Independent Variable Cam Timing (Ti-VCT), which allows the power-train control module (PCM) to advance and retard intake and exhaust cam timing independently of each other, providing improved power, fuel economy and reduced emissions. The engine also receives a new composite intake manifold with a single blade 80 mm (3.1 in) throttle mounted low and center, necessitating a relocation of the alternator to the side of the engine. The Boss 302 features a newer short-runner composite intake manifold. The engine is assembled in Ford's Essex Engine Plant in Windsor, Ontario, using existing Modular tooling.[14]
For the Australian Ford Falcon-based FPV GT range, the engine has been equipped with an Eaton supercharger.[15]
The 4-valve DOHC Ti-VCT 5.0 L made Ward's 10 Best Engines list for 2011. [16]
Vehicles equipped with the 32-valve DOHC Ti-VCT 5.0 L include the following:
2011 Ford Mustang GT, 412 hp (307 kW) @ 6500 rpm, 390 lb·ft (529 N·m) @ 4250 rpm
2011 Ford F150, 360 hp (268 kW) @ 5500 rpm, 380 lb·ft (515 N·m) @ 4250 rpm [17]
2011 Ford Falcon GT,[18][19] Supercharged, 449 hp (335 kW) @ 5750 rpm, 420 lb·ft (569 N·m) @ 2200-5500 rpm[15]
2012 Ford Mustang Boss 302, 444 hp (331 kW) @ 7400 rpm, 380 lb·ft (515 N·m) @ 4500 rpm [13][20]
Checkout the link http://wn.com/Ford_Coyote_engine
  #34 (permalink)
Old 03-16-2011, 11:41 PM
and it can set off car alarms as it passes....
  #35 (permalink)
Old 03-16-2011, 11:45 PM
fordracing65's Avatar
Same engine as the dohc cammer, its been winning races for years now.
PRIDEnJOY
  #36 (permalink)
Old 03-16-2011, 11:53 PM
Cobra Make, Engine: RCM, 4 wheels, two doors
steve
If I had to do it again, I'd think about this.....
Using a standard Ford Block
1100hp on pump gas, 1400hp on racing gas
I Luv Ford and the guys at NRE!
http://www.nelsonracingengines.com/v...reet-Test.html
  #37 (permalink)
Old 03-17-2011, 06:43 AM
Kanga's Avatar
Looks like the old weezing 5.4 needs a couple of turbos to wake it up.
Rate This Thread:
