I think they will fit but you'll need to use a filter box similar to Phil Mizzi. This would probably be a good thing because every time you open the bonnet the trumpets would be fully exposed!
Regards. |
Just to add more confussion Paul.
http://www.efihardware.com/products/c16/Throttle-Bodies If you look at the Windsor kit, the throttle bodies dont look too bad. http://www.efihardware.com/_linkedim...h-rams_483.jpg |
Irintakes.com makes a down draft 48 Ida manifold that would work with the dynaformance system and a LS1 .
Thanks Jaspittman i will look them up.
Have got a price for the set up from Dynaformance. $6600.00 rather dear i think. |
before u buy any aftermarket webber lookalike throttlebodies
make sure u physically look at them in your hands ive seen afew over the past years and would have resevations on using em on my car if i had one that needed em the final finish is sort of ok not perfect also very fiddly to set up i had to fit a tripple setup to a holden 6 motor last year and fkt round so much i just got sick of them getting fuel lines to line up with injectors and linkages was big pain in the butt id go for the 8 single throttles u find on hot rods in the states but just ask many questions and maybe even go look at some fitted to cars as i have not seen many good looking and user freindly kits made in australia |
Thanks Jim ,I will take your advice.
They look great in the pics but fitting them and getting them to work may not be worth the money or trouble. Thanks again Paul |
| All times are GMT -7. The time now is 04:52 PM. |
