The Hoops are Getting Bigger
I hear that the RTA (NSW)require test results for the Side impact / Side Door Strength (ADR29 )
Would this be a crash test or a simulated test ? Do kit builders supply these tests? Has anyone from NSW building an ICV been asked for this test? Has this been asked for in other states? I don't remember this being a requirement in Qld when my cars were registered. Warren |
re intrusion bars
I'm at work right now but I think my engineers report mentions side intrusion and the requirement to have intrusion bars fitted....the RMC came with them fitted in 2002.
I'll check later. |
And in Harrisons since 2008 at least.
I am not saying, do you need intrusion bars in doors, that is a given and is explained well in ADR 29.
What I am saying is that a report is now required to the effectivness of them by a crash test or calculated by a simulated test. You just can't put steel in the door as per ADR 29 and say you have intrusion bars. Now you have to prove they are effective. Warren |
I know that in 2008 my engineer needed photos and details from Classic Revival to check. I am assuming that he had to do calculations to prove that they were suitable.
He also needed detail about the hinges and locks to make sure they complied. It will be a big problem for new builders if they insist on testing now! Ben |
Testing of side intrusion bars is not a requirement. The RTA provide exemption for the testing requirement of the ADR but not the performance requirement. The engineer needs to provide evidence that they have assessed the adequacy of the structure by comparison to a production vehicle, calculations or FEA. They cannot just say 'the car has side intrusion bars - tick'.
According to the RTA, the problems that ICVs have been having in the last 2 years is attributed to engineers approving things based on visual inspection with no work being done to provide evidence for compliance. Its the same for suspension mounts and any modifications made to factory OEM parts. From the conversations i have had with people at the RTA from Safer Vehicles, they just want more evidence of compliance and not just visual inspections. |
What Liam says is absolutely spot on. Take it from me as I have recently been through that hoop. The Signatory Engineer must prove by way of calculations acceptable to the RTA, that the side intrusion bars or for that matter, any other modified OEM part, is capable of performing the duty that they are designed for and not just say they comply with the NCOPLVM. Baz |
Gday Baz,
Hows the leg? Have you been getting the cobra out to enjoy the new rego? |
This an extract from the email I read yesterday. I did remove the kit builders name and the type of ICV.
"but now the RTA require that I or the engineer produce some test results for the (Side impact / Side Door Strength ADR29 ) normally this is a crash test or a simulated test . The kit builder's submission letter compares the ICV door to a Commodore which is now not acceptable" This ICV uses factory hinges and door latches from a late model car. Warren |
I cant comment without seeing the full context of the email. Baz's car passed rego a couple of weeks ago and that didnt require side impact testing.
There are a few other ICVs that i am aware of and none have required destructive testing, but all require some sort of analysis to be conducted by the engineer. |
I just went through my records and dug out a letter i recieved from the senior vehicle engineer vehicle standards RTA on 16/11/2010.
Extract: Quote:
Yes Bernie you are right. Mine was assessed as comparable or better than the current production vehicles for that year...no tests or stats required in 2002.
| All times are GMT -7. The time now is 02:19 PM. |
