01-26-2012, 10:04 PM
Cobra Make, Engine: Harrison Cobra 118, Alum 427,Manual C4, 9'DIFF, 4 LINK rear Suspension
Side Pipes
Hello All, First timer at using Thread. I'm building a Harrison Cobra, But trying to understand how to connect side pipes to extractors without using a flex joint all photos I've seen dont have any. But I believe that if you dont use flex joint how do we get away with holding side pipe to chassis as they are fixed solid??? this would cause undue vibration. Am i correct in saying this.
01-26-2012, 10:25 PM
vic
My side pipes are mounted with rubber mounts, two on each side.
They don't melt as they are on brackets off the pipes.
The pipes tilt with the engine as it moves.
They will move ALOT when launching off the line at the drags!
Powered by Cu
01-27-2012, 12:12 AM
Welcome RAAPS. Will this be a street car in QLD? I am not sure on the regs on live pipes after a recent thread/post by Treeve.
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
01-27-2012, 01:38 PM
Thanks for response, Yes Merv street car in QLD. As we do went building we are always thinking ahead, Im still 10 mths away at this stage to have finished for Rego.. But I trying to get different areas placed in my head on how it will work, So your info is helpful. I have being told that QLD rules state you can have side pipes but they must still exit rear so we would have to turn them in front of rear tyres then exit out back. After Rego and inspection remove rear tail pipes is my idea. But have a local guy here building a DRB he states his engineer has past side pipes for rego But they must be coated for heat ?? I still believe Qld transport will fail it??
Craig
01-27-2012, 02:13 PM
To my knowledge the side exiting pipes are still illegal in QLD for new Cobras, but in SA there was a recent post:
Working side pipes now legal in South Australia
Also, the way you are going at it seems fine, to me at least. Deciding, after registration, to remove the rear routing and exit in front of the rear tyres, is up to you, the local cops and your insurance company (they will always look for an 'out' in the case of an accident), however.  Very few of us have done that, as the cars do attract a lot of attention, but the rules may change in QLD at some stage.
Keep us posted. The Harrison is a pretty good product. Did you get the extended body?
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
01-28-2012, 05:57 PM
MI
Here's a step-by-step retrofit with good photos that may help. As already mentioned, the brackets are welded onto the mufflers & then attached to the chassis utilizing rubber isolators that dampen vibration & will tolerate movement. (forget about my mufflers - not trying to sell them to you - just showing the muffler assemblies & how everything works). Also, the actual hanger part we left attached to the chassis during all this - we just needed to be able to position the tabs onto the mufflers.
-Eric
Classic Chambered Exhaust Inc. - Cobra
01-28-2012, 08:11 PM
Eric, just curious about your wheels, can you tell us who makes them please?, I reckon they look great!
Regards.
Mando
01-29-2012, 01:48 PM
Merv, yes it's the 100mm version, Will up some photos once I work how to do it!!!!.
01-29-2012, 01:51 PM
Eric thanks for the info about your product will keep in mine when ready, you answered a lot of questions.
Ill stay in contact.
Craig
01-29-2012, 02:03 PM
Follow this Eric.
help with posting photos
Merv
Ford Cobra
Harrison #80.
Peregian Beach
Sunshine Coast Qld.
02-02-2012, 08:10 PM
MI
Regards.
Mando, they are OEM wheels - all made by either Kelsey-Hayes, Motor Wheel, or BUDD. I put them on my website just to make it easy on myself - I probably should do a separate website for them. Found a source for them back in 1998 & have been selling them longer than I've been making mufflers! I was looking for 15x7" wheels for one of my Cudas & one thing led to another. I'm really the only dependable OEM steel wheel supplier out there.
