Like Tree4Likes
  • 1 Post By Gav
  • 3 Post By 07cob
Old 09-02-2014, 03:53 AM
Default Harrison Front sway bar
Hello Harrison owners,
Has anyone fitted a front sway bar to their Harrison Cobra?
Stiffy
Old 09-02-2014, 04:56 PM
Towmaster's Avatar
Peter Hancock has just made a custom one for Wazza's old red racer. I am not sure what they do for them. Have a chat to John White at the Nationals, I am pretty sure he had one on his Turbo Lexus Harrison. (assuming u will be there?)
Old 09-02-2014, 05:16 PM
Default Front sway Bar
Are we talking original "A" arms or new dunnydore front end?
Old 09-02-2014, 06:32 PM
byroncobra's Avatar
No sway bar on my Harrison but I'm taking it up to Scotty at Venom before the Nationals for a suspension tune up.
Funny I was going to ask him about a sway bar.
He had a lot to do with the early cars (mines a double A arm) might be worth a call for you.
Greg
Old 09-03-2014, 12:00 AM
Default Sway Bars
Guys,
Thanks for the reply's, mine is the Dunnydore A arm model (2007 chassis).
As it comes standard with the rear R32/33 assembly which already has a bar
attached it might be worth while adding a front.
I am going to the Nats so I will have a chat to Sneeky Mr White and
Hancock and Co. Is Wazza's old car quicker without him in it or has the front
bar made a difference........
STIFFY
Old 09-03-2014, 04:38 AM
Stiff, when my chassis was being built I asked Warwick about the rear bar, I'm using an R33 rear end and Warwick said NOT to use it. If I remember correctly he said it made them a tailey.
I still have it, thought I might need it one day-( if I ever get it finished )
Rog
Rog 246
Harrison #100
Old 09-03-2014, 09:50 AM
sambo's Avatar
What problem are you trying to solve Stiff? I had negligible body roll at Winton with fairly conservative spring rates. Roll bars front or rear are for dealing with over or understeer as far as I understand.
Old 09-03-2014, 05:11 PM
Default Bars
Rog246,
I wish Warwick had of told me that maybe he didnt as we were in the
same class AND I was a tad quicker.........
SAMBO,
The majority of cars have at least a front sway bar, it must be there for
a reason, having a rear ONLY must cause issues. Maybe I should just remove the
rear and see if that works.
Stiffy
Old 09-03-2014, 05:20 PM
Gav's Avatar
Gav Gav is offline
I know mine is not a Harrison, but it suffered shocking understeer prior to the front swaybar being fitted.
The rear bar stopped it lifting inside front wheels :0
And oil surge stopped it dead
Powered by Cu
Old 09-03-2014, 07:11 PM
whats the car doing ? we change sway bars all the time on our commy race cars on dirt even between races depending on the what the track is doing . my prefrance is soft springs and sway bars to support the car thru the corners where other blokes prefer stiffly sprung cars with no swaybars . my view is if you are going to run sway bars then you need them both ends of the car . the tricky bit is working out what rate you need .
Old 09-03-2014, 07:22 PM
sambo's Avatar
No sway bars on mine Stiffy. It feels pretty neutral too. I didn't have the balls at Winton to push hard into corners so I can't really say how it would behave - I just assumed it would go bad very quickly - and I had to consider the drive back to Melbourne.
Thinking more about that scenario... I'd probably want a bit of understeer. Lift off the throttle and hopefully the nose tucks in nicely.
What are your spring rates front/rear?
Old 09-03-2014, 07:35 PM
Default Bars
Gav,
Maybe if I looked at my gauges I might suffer from oil surge also
Deano59,
I agree, it must have both.
SAMBO,
From memory the fronts are 450, the rears 250/275. My car is quite
Neutral at lower speeds and predictable at speed with under and over steer.
When I look at photo's of my car going thru corners, it leans more than other
Cars thru the same corners and at about the same speed. Therefore it would
Appear that one is needed, but where to fit is the issue, it's pretty FULL under
The bonnet.
Stiffy
Old 09-04-2014, 10:57 AM
sambo's Avatar
Stiffy, I reckon you need to do some back to back testing with and without the rear bar fitted. Maybe a slalom where you can weave through witches hats at increasing speeds to see what feels better. Personally I think some of the best Cobra photos are where there is a bit of body roll... full attack!
Old 09-04-2014, 04:28 PM
Gav's Avatar
Gav Gav is offline
Sambo,
Your car performed really well at the Shelbyfest, but I am sure once you get some stickier rubber under it you will be wanting more from the car.
A front sway bar is a must if you are wanting to have a crack and IMHO a rear one is definitely worth having too.
sambo likes this.
Powered by Cu
Old 09-04-2014, 05:59 PM
sambo's Avatar
Thanks Gav. I was originally surprised that Harrisons are not fitted with sway bars by default.
Can we hear from a few other Harrison owners? How about those faster drivers in QLD?
Old 09-04-2014, 06:30 PM
Default Bars
Gav,
I agree, all track cars should have at least a front bar, and as the
Harrison has a rear bar as standard the front is a no brainer.
Space is the only issue, especially in the Daytona as they are a bit longer and
wider than the Cobra chassis and with the inner guards incorporated in the bonet.
I will take a squiz at the Cobra Harrisons to see how they did their's.
STIFFY
Old 09-04-2014, 06:39 PM
sambo's Avatar
Stiffy do you have any photos of your rear sway bar? Keen to see how it's fitted up to the chassis.
Old 09-04-2014, 08:31 PM
Default Rear
Sambo,
The rear bar comes as part of the Nissan rear asembly, it should
be the same as yours.
Stiffy
Old 09-04-2014, 09:40 PM
sambo's Avatar
Ok yeah I remember leaving it off mine. A light bar front and rear makes sense.
Old 09-04-2014, 11:29 PM
07cob's Avatar
Gents
No rear or front bar on mine. I asked Warwick at the time and he said get rid of the bar from the R32 rear end and there was no need for a front bar. Here is the extent of the body roll going around the final turn at Morgan Park.
After a session at Morgan Park at the recent club day and some discussion with Towmaster, I have considered a front bar to reduce some oversteer. It is not much but a front bar could help.
Geof
schipps, sambo and muzzza like this.
