248Likes
11-04-2015, 06:55 AM
sa
Originally Posted by renovationinnov
what happened to the paper less sericites
I thought you would have it on memory stick & then play it on you tv in the man cave dean
then you could see it better
one old fart to another
rob
not a bad idea but i reckon if i put a tv out here i wouldn't  get much work done . i have the radio going in the background if that helps.. i have just put page 300 into a sleeve and thats me done for the night. i also managed to cut out the insulation for the tunnel and fire wall i dont think that pair of scissors will ever be the same again
cheers from dean
11-05-2015, 03:43 AM
NSW
Cobra Make, Engine: Pace 427 (#53) , LS3, TR6060
Ummmm, what happens when they release the updated version?? Reprint????
11-05-2015, 04:21 AM
sa
hopefully it will be built by then :-)
11-15-2015, 04:57 PM
sa
hi all
had a bit of spare time over the weekend so i invited a couple of mates over to give me a hand in taking the body off the chassis and getting the chassis up on stands . this is where it will live during the build .
work can start in earnest now .
cheers dean
11-15-2015, 05:04 PM
Vic
Cobra Make, Engine: Cobra Replica, 5.0 Supercharged Coyote
Looking Good Deano, Here's a little build tip, file any sharp edges in the engine gearbox tunnel smooth.
11-15-2015, 05:09 PM
Vic
looks great, the finish on these things is second to none.
looking forward to the build.
11-15-2015, 05:33 PM
sa
cheers for the tip will do :-)
11-15-2015, 09:22 PM
Cobra Make, Engine: Pace 427 LSA
Looks like you are all set up now to start building. Enjoy, I know I am loving it!
11-16-2015, 02:09 AM
VIC
Another tip. Pad the corners of the rear wheel arches!mthe number of stabs and scratches I got on my back, sliding under the chassis while doing the diff, etc, was extremely annoying!
Guy
11-16-2015, 06:08 PM
Cobra Make, Engine: Absolute Pace 427 SC
Hi Passenger
Just wait till you drive it the feeling is just beautiful.
I have 9,000 kms on my Pace Cobra now in just 12 months.
Brad
There is nothing better than a cold beer
11-16-2015, 07:47 PM
sa
Originally Posted by Cobra01
Hi Passenger
Brad
i bet we couldnt wipe the smile off ya face with a bitter lemon yet either brad :-)
11-16-2015, 08:14 PM
Yeah definitely looking forward to driving it, 9000km in one year! thats what I hope to do with mine, drive it at every chance I get.
11-16-2015, 11:34 PM
wa
Or buy a 2 post hoist.....I could never go back to laying on the ground.....hmmm so toffee these days......actually good advice might take an eye out on those corners....
11-17-2015, 06:13 AM
sa
i dont have the height in house carport where im building the cobra for a hoist even my main workshop the other side of the block almost 60 by 25 wide is not high enough the guy before me that built it only wanted space and not height so i live with what i have .
mind you the next house will be a different story ..
11-26-2015, 03:14 AM
sa
spent a couple of hours mounting the rear sway bar this arvo i had to modify the plates the bearing carriers mount on as the holes didnt line up . updated carriers with different bolt patten ten minuites with a die grinder had it sorted and ive let pace know all mounting plates supplied now will be the correct ones no big deal just had me scratching my head for a few mins and gave me splinters.
apart from that all went together quite well i just need to drill and tap a hole on each top wishbone where a bracket bolts too and thats one job crossed off the list on the whiteboard tomorrow hopefully will see the hole cut out of the firewall for the pedal box then i will start with the insulation and brake and fuel lines ..
some pics of todays effort
11-26-2015, 03:30 AM
Vic
Drill and tap?!?!?!?!?!? I thought this was a Pace ???!?!?!?!?!?!
Ben in AU
11-26-2015, 03:47 AM
sa
i optioned up to the sway bars as a last minute thing im sure if i had have gave them more warning the holes would have been done for me ..i need some actual work hell even ikea give you a allan key to help bolt things together lol not all the car is ikobra flat pack
11-26-2015, 04:30 AM
SA
How long has Pace been making this model with that type of suspension?
Nice to catch up the other day.
JD
11-26-2015, 04:56 AM
sa
JD
this is the only suspension they do it changes a little depending on what size rims and brakes you decide on . i believe there are not many that have taken up the sway bar option i may be wrong on that but i dont think so .
always good to put a face to a name your welcome to visit any time .
i will drop in and check out your car when im down that way ..
cheers dean
12-08-2015, 07:46 AM
wa
Deano what's he latest?
