-   -   rpm (http://www.clubcobra.com/forums/australian-cobra-club/20975-rpm.html)
347 10-14-2002 06:29 AM
rpm
i have quad 44 mm idf webers on my 347,does anybody have an opinion about where/what rpm the engine would slow/stop reving and makeing power??
Jeff Frigo 10-14-2002 05:05 PM
Depends on the cam. Give us the specs. and we can get pretty close.
347 10-14-2002 05:13 PM
cam specs: comp cams 294s,294 adv,248 @.050,560lift,110 lobes,
347 10-14-2002 05:14 PM
i forgot its a solid flat tappet
750hp 10-15-2002 04:36 AM
Lots more details would make the guesses closer to the mark.
Cylinder head flow numbers, valvetrain specs (Rocker ratio, valve spring pressure), exhaust header diameter and length, exhaust system diameter, ignition system, ram tube length, compression.
347 10-16-2002 03:20 AM
ok here is what i know:int 298 @.600.309 @.700,exh 200 @.600,209@. 700,rocker ratio 1.6, 1 3/4 headers 4 into 1,40inches long,duel 2.5 inch pipes ,accel dizzy,crane ps91 coil ,hi 6 box,no ram tubes (k&n filters)comp 10.18.1
